Results 1 to 10 of 13
Thread: antenn's with usb wifi?
    FLAC djmickyg's Avatar
    Feb 2004
    here is a pic of the inside of my promix usb wifi card
    it has 2 large solder traces on the board which would be the antenna
    if i were to solder a small legth of antenna wire to them and conect a n-type connector to the end so i can attach a proper antena.. would this work..
    would i use both solder tracks?
    i hope this makes sense?
    thanks mick
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    should. done it with a belkin g54 usb. I put N connector to it also to connect it to a 1w wifi amp.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Feb 2004
    did urs have 2 onboard antennas like this one??
    Mar 2004
    Fort Myers, Fl
    yes. by the picture you posted i recommend soldering the center wire of the N connector to the conection on the left. I will get pictures of mine posted later today.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Feb 2004
    thanks... do u know where there are 2? what does the right one do??
    Mar 2004
    Fort Myers, Fl
    center pin of n connector solder to the left, solder the outer pin to the right.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Feb 2004
    well i fonally got around to this..
    its working fine (outside the car)
    sorry bout the quality of the pics.
    here is my little wire from the board
    out the little hole i drilled
    the antenna, its about 20cm long and ment to have a 7db increase
    and the verdict..
    i didnt think it would actualy make much of an increase because ive got about 2m of wire b4 the antenna.. i just wanted to be able to have an external antenna cus the car blocks out to much
    but it actually does a little
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    dunno all that much about wifi (yet) but i believe i read something about two antennas not being all that good.
    I think you'd be better off to just loose the internal antenna and connect your wire directly to the leads that go to the metal pads. (if this makes any sence)
    A good starting point about wifi is netstumbler.org, might be worth checking out what's going on there.
    Hope this helps
    '03 BMW 320d (E46)
    Carputer progress : [#----------]
    Gathering information ... currently using my phone connected through BT as carputer
    '99 BMW Z3 coupe 2.8
    Carputer progress : [-----------]
    No work done yet
    Variable Bitrate numbers's Avatar
    May 2005
    If you still care...
    If the two meter cable run is the same lmr195ish stuff shown in the picture, replacing it with some lmr240 would almost certainly decrease signal loss noticibly.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    also if you desolder the shield of the coax from the 2nd antenna and solder if to the casing you should get even better signal, by soldering the line to the 2nd antenna your not giving the cable a good shield.
    肚子笑痛了
    S60 Install
  1. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  2. stupid usb slimline DVD drive
    By ummagawd in forum General Hardware Discussion
    Last Post: 04-26-2005, 02:57 PM
  3. Anyone want to trade? I have Wifi PCMCIA card, need USB!
    By Urinemachine in forum Classified Archive
    Last Post: 04-03-2005, 03:03 AM
  4. usb wifi with detachable ant?
    By meyer64 in forum General Hardware Discussion
    Last Post: 03-30-2005, 01:46 AM
  5. USB Soundcard Woes
    By phc in forum General Hardware Discussion
    Last Post: 02-11-2004, 06:02 PM
