Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: confuse wifi card (reboot software needed)
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Sometimes my network card (when under high traffic conditions) just seems to lose the plot, it drops out and hangs.
    This is annoying if 400mb into copying a 500mb file and its happened more than once.
    so, next time I leave it copying a file and it stops, can I get some software to reboot the machine?
    I know thats a bit drastic but its xp not linux, linux could proably just unload the driver and re-load it etc.....
    So, software to reboot the pc if nets gone down, checked every 5 minutes or so? gentlemen start your hard drives...........
    Elsewhere
    Double-check the properties of that device and make certain there's no power-saving enabled for it. I've run into this on other computers where a NIC shuts off to conserve power and anything going across teh network is hosed.
    How about the Wiki?
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I dont know about getting the signal back, but i use download accel, and it will continue downloading from the spot it stopped.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Yup I fixed that, and then turned auto-reconnect on, but it seems to crash at a more hardware level.
    Its just really damn annoying when Icomeback to it after an hour (or a sleep) and find its only ftp'd 25% of my mp3's or something.
    If it rebooted it could continue by itself etc
    Such software must exist for windows, its not like a hang is unheard of with xp users......
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by Pokey
    But if I dont return to the machine for 12 hours its been wasting 12 hours of time and power.
    I need it rebooted.
    Then the software (emule, bitlord, ftp in startup directory or whatever) can resume where it left off.
    This started as a crash when in ftp from server to car pc problem, I just mentioned internet as a simple ping to google/ibm/msn etc is a simple way to see if the card is still up.
    Tampa, Florida
    Quote Originally Posted by lez
    I need it rebooted.
    I'm not a programer, but on my server I have it reboot every 24hours, whether it needs it or not. I know its extreme, but maybe in your case, reboot every 'whatever' when you're away...
    just a thought
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Ok, another scenario
    I have some p2p software running, and I've been in a q for 8 hours trying to get that last 1mb of 'earth 2 the complete series 1 dvd' because I cant buy it anywhere.
    Now that download would never complete if I reboot every hour, because I would fall from the q
    If the stupid card hangs I dont mind rebooting as I have fell from the q anyway, but that wont happen every hour.
    Sometimes the card can go a few days with no problem, then it can go to lunch twice in an evening
    I have just had another google to no avail, too many hits or not enough because the keywords are too vague, but someone must have a piece of software to do this.
    'every 5 minutes check connection alive, reboot if not'
    Variable Bitrate numbers's Avatar
    May 2005
    It would actually be a terribly easy program to write. Find someone capable and they should be able to do it in an afternoon.
    Jan 2004
    If your using a 802.11G card try setting it in the B mode. G mode is supposedly a bit flakey. A lot higher transfer speeds but I was warned they crash all the time.
    Are you running XP? If your card is just over heating and quitting, I would download this shutdown program.
    http://www.budja.com/shutdown/
    Then I would grab a cron program that's better than Windows Scheduler. Windows Schedular will do daily, but not hourly jobs.
    http://www.downloadjunction.com/product/software/30619/
    Jan 2004
    Another thing. My wife was complaining that her wireless was going down all day. When I got off my wired computer and turned it off she had no problems after that. maybe you can be having the same problem.
  1. Help needed choosing software
    By sremick in forum GPS
    Last Post: 10-26-2004, 12:37 PM
  2. Wifi software???
    By Rafster in forum Software & Software Development
    Last Post: 04-16-2004, 01:06 AM
  3. fs/ft datalogger card and software
    By indysho90 in forum Classified Archive
    Last Post: 08-13-2003, 12:34 PM
  4. Shortcut software needed, could solve problems
    By dudah85 in forum Software & Software Development
    Last Post: 09-13-2001, 11:21 PM
