At 7 miles, you will need a couple of towers.......the speed would be low as well, mainly because of the distance and the number of retries necesary to maintain communication between the 2 points. Check www.wlanparts.com for idas and hardware for longer distance wifi links. Obvioulsy this has nothing to do with mobile technology, but it may get you started....
One other option is the wireless network from the cell providers.... You can purchase a PCMCIA card from T-Mobile ($200.00US) that has tri-band and Wireless protocols, all-in-one. You could utilize the cellular network a lot easier that trying to shoot a 7 mile wifi link...
We currently shoot a signal from Vancouver Washington to Portland Oregon for a community based internet non-profit. It works pretty well. We service about 30 units in one location and anther link is going in for about 30+ more. The link is probably close to a 4 miles "as the bird flies" and we get pretty good speed across.... (www.qorvus.com)(www.netequality.org)
Personally, if you have the cellular signal in your area, try out the service on your cell phone and see.... it will be cheaper than all the equipment to set up a 7 mile link. The Senao doesn't seem to have the "oomph" at 200mW that the SMC card does. Either one will work if you get the external antenna. I would put a unit at each end and then branch off from there..... that way you have a static spot for each TX,RX point....
But hey, that's just my 2 cents.....(on a side note, where the hell is the cents character?)
LinkBack URL
About LinkBacks
