Maybe you can write your own apps to do the click for you.
You can try to do a little search for Routis/Iguidance and warning on how people come up with app to auto click OK on the warning window. The same idea, different apps.
i'm using verizon's highspeed card. i use windows connect to connect, not the verizon software.
when i go 'start/connect to/verizon'
it gives me a little status/pre-dial monitoring window that says 'ok' in it, and i have to click 'continue' to connect.
i don't understand why - is there a way to disable this? i went under properties and unchecked everything having to do with status windows.
i don't know what i'm missing, i went over it a dozen times. anyone know how to get rid of this stupid status window?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
howardforums.com
