This is incorrect. Only one house phone rings. The only way you could get multiple phones in your house to ring would be to have the Merge unit connected to the base station of a cordless phone system that has expansion bases... then each expansion base would ring too.Originally Posted by Tanner
As far as the rest of your post, I have read it at least 20 times and I can't figure out what you are saying. The Merge unit simply acts as a "switch." It takes one input, ie: a phone or a modem, and switches it between two outbound pipes, ie: cellular service or a landline phone line.
Inside your car, there is only one outbound pipe available to you: a cellular service. All Merge does is let you switch a device between two outbound pipes, and in a car you only have one outbound pipe (ceullar service), thus Merge is useless in a car.
If you want to place calls from the Car PC's touchscreen, why not get Phonecontrol.NET?
LinkBack URL
About LinkBacks
