Hirschmann makes antennas for what you want. They're made for vehicle mounting.
hey guys i did a lil bit of search and i found this thread
here
and i found the links on there to some good stuff by dlink
here
here
my card is this one
i had 4 questions...
1. can i just buy up a antenna with the right connector and plug it into the card or does it have to be a specific one?
2. what kind of connector does this belkins card have?
3. can i mount an indoor antenna on my roof if i waterproof it? and would it make an impovement?
4. can i buy the wire with the right connector extend it from the pci card to my roof drill a hole bring it out and connect it to the original antenna?
I have a belkin PCI card. It worked fine in the boot(trunk), but I have made up an extension cable and the aeriel not sits on the rear deck.
You just need an sma extension lead,
can you post a picture of how urs looks?Originally Posted by Enforcer
Tried taking photos, wasn't very clear.
These might help.
They are actually Reverse Polarity SMA connectors
Male:
Female
here's a made up lead on EBAY (UK)
http://cgi.ebay.ie/2M-Antenna-Extens...QQcmdZViewItem
so basicly if i got that connector and ran a wire in between it pluged the male end into the comp and the female end would run to the roof and connect to the stock antenna from the wifi card it would work??
but which wire would i need?
and can i use my stock antenna to get better range or no?
RG58 cable, make sure the plugs you get are for that cable as well.
The first plugs I got were for a thinner cable and I had touble getting the plugs to stay on.
You should be able to get a made up cable, check ebay
in fact, I've done the legwork for you.
http://cgi.ebay.com/RP-SMA-Extension...QQcmdZViewItem
try the stock antenna and see how it goes, you can always get a better on later
u freakin rock :-) thank you!
ill be gettin that once i get some funds at hand
How did you guys remove small Belkin WiFi Antenna? I am looking at it now and I am afraid to break it. Should I just snap it off or what?
