Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: WiFi Antenna w/ 1W amp through Tint.
  1. #31
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Since someone thought this was good advice, I'll follow it up with specific product recomendations:
    Senao/Engenius sells really great gear in a variety of forms: PCI, usb, ethernet bridge, PC Card, etc.
    In almost every form factor you can find a 200mW card with great recieve sensitivity. Plus, they have external antenna connectors (you buy a pigtail to adapt from the radio's tiny connector to an 'N' connector, then your antenna has an 'N' connector). These cards coupled with an good antenna (hyperlinktech.com) will get you really great range. You may still have problems with the tint. But this is a much better alternative to an amp.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  2. #32
    Jul 2004
    @kbyrd: thanks for the contribution
    Here is the spec sheet for the commel 2400 card:
    ftp://ftp.commell.com.tw/Public/Data...al/MP-2400.pdf
    Can someone smarter than me interpret this: "Output power: 12~14dBm (54Mbps), 18dBm (11Mbps)
    Does this mean that as is, the card provides from 12dB to 18dB of gain? That sounds pretty good to me, no? Is there any real need for another antenna for this card?
  3. #33
    Nov 2003
    Northern Arizona
    Quote Originally Posted by Jackboot
    I'll interpret (check here: http://www.terabeam.com/support/calc...s-dbm.php#calc )
    12dBm = 15.8 milliwats
    18dBm = 63.1 milliwatts
    this isn't "gain" it's output power. Every 3dBm = double the output power. dBi is gain for an antenna. The Senao cards I mentioned are 200mW (23dBm). That sheet doesn't mention recieve sensitivity (few spec sheets do), but that's the other half of the "getting a good connection" equation. It doesn't matter if the other end (the AP) can hear you if you can't hear them.
    My worklog.
  4. #34
    Aug 2005
    Quote Originally Posted by kbyrd
    Do you have to use an amp?
    Wifi amps are bad, mmkay?
    The introduce noise and amplify noise as well as signal. I would really only consider using an amp in a wifi setup if I had a long antenna lead run from the antenna to the radio. In that case, the amp would go at the antenna end.
    If your case, I would just user a higher gain antenna and a higher powerer/more sensitive radio.
    Well after some of the posts so far, this idea is looking better. I hadnt heard the negative side of using an amp untill this thread so.. Appreciate the input..
  5. #35
    Newbie agmsd's Avatar
    Oct 2005
    I would like to apologies to SKiTLz.. for Hijacking his thread... It just poped to my mind.. hope that u accept my apology... thanks...
  6. #36
    Aug 2005
    Quote Originally Posted by agmsd
    hey no problem mate.. hope you get the answers your looking for.
  7. #37
    May 2005
    so is there any problem with using an amplifier with an antenna outside of the car?
  8. #38
    Nov 2003
    Northern Arizona
    I'll quote myself. I'm not saying amps are more dangerous than a high powered card and a high gain antenna. I'm saying there are VERY FEW (are there any?) circumstances you should ever use an amplifier with wifi. It generally causes more trouble than good. The cable runs are short enough for us (how big is your car?) that a good antenna and card is a better choice.
    Inside the car/outside the car, no amp. Spend the money on better wifi gear and a better antenna. If you're really paranoid about a long cable run (when I said "long" in the quote above, I mean >50 feet not six feet to your trunk), use high quality cable, LMR-200 (or LMR-400 or LMR-600, but that's got to be overkill for a car).
    Keep in mind that I used the gear I'm talking about to setup several 3-10 mile links. So, a 2 foot omni antenna and a 200mW card in your car should pick up nearly any access point you car about.
    200mW is a lot of power. Combine that with an 8dBi omni antenna and you're likely too find an access points everywhere.
    My worklog.
  9. #39
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Sounds very much like you know what you're talking about. I imagine lots of people are interested in this so I vote you should condense this thread into a mini FAQ Kbyrd.
  1. Anyone using an 802.11B amp & high gain antenna combo?
    By DriverDan in forum Wireless Communications
    Last Post: 03-06-2007, 12:52 PM
  2. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 07:43 PM
  3. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 09:11 PM
  4. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 07:35 AM
  5. Any way to use your car's antenna as a WiFi antenna?
    By NoNonsense in forum Wireless Communications
    Last Post: 07-17-2004, 10:34 AM
