Results 1 to 10 of 13
Thread: Dialup access w/o using carrier's ISP
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Does anyone know if its possible to dialup to a network, such as a Work VPN on a cell phone, but not use the carrier's ISP? I wonder if its possible to use the cell phone as a modem like you would using their access. I have Cingular and a Nokia 6230.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    and pay through the arse ....
    Just connect via VPN..
    You will have an IP(dynamic) on the cell, and as long as ports are not blocked, it can be used just like from home etc ...
    Jun 2004
    Virginia
    Quote Originally Posted by Don 944 LA
    Why can't you make a modem connection over the analog/voice channel, like on a regular phone line and use free minutes?
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by warnockm
    You can, i did that for a while all it does is use your minutes.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jun 2004
    Virginia
    how did you connect? did you use the modem built into the phone or another piece of hardware?
    Nov 2005
    heres how i do it, when i connect my phone it calls it something along the lines of usb motorola modem, then i just create my dial up connection so it uses that as my modem, then i just let the phone sit- the computer controls the dialing
    hope that helps
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    Be careful. Some providers consider data calls different from voice, and actually bill them.. even if they're inside your unlimited minutes. Devilish, Yes. Unethical, Yes. A reality in this world of corporate greed? Yes.
    So check first to make sure you won't be billed 25cents a minute. :P
    Variable Bitrate lerandell's Avatar
    Mar 2004
    Ennis,TX.
    there are lots of way to do this. It also depends on the phone hardware, carrier plan and type of network the phone is on.
    do you know what type of phone you have?
    Analog-
    Digital-
    GSM-
    FYI - years ago I did see someone connect over an analog cell phone. and it sounds like that is what you are wanting to do.
    Randell Kelly
    Constant Bitrate bluehcc's Avatar
    Jun 2004
    Queens, NY
    It depends, some phones work and some don't. I point my cell's infare to my laptop's infare, and then once it detect something near by, and finished install modem hardware. then you can create a dial up connection choose the cell phone modem which has just installed. The drawback is that its very slow. You are killing your minutes. Its free if you have weekend and night unlimited minutes.
    Mar 2004
    Ennis,TX.
    My nokia did that as well over the infared ports. I was able to install it as a modem but when I tryed to dial it out it would bomb. I found out that at the time my carrier did not support data modem connections oved CDMA.
    I now use my Blackberry 7100t connected via USB cable over the GPRS network. I get somewhere around 20k.
    Randell Kelly
  1. Weather and traffic reports w/o internet access?
    By egeekial in forum General Hardware Discussion
    Last Post: 09-16-2004, 02:58 PM
