Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 100
Thread: Engenius/Senao USB Wireless adapter
  1. #51
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by zer00 View Post
    It's all the same product regardless of the badging on it (Senao/Engenius).
    But the reason yours is different is because it looks like you got the EUB-862 EXT which is the new A/B/G version of the 362 (which I didn't even know was out yet). Congrats.
    BTW, I am new here
    The join date kinda gave that away.
    Failure is not an option....
    It's installed by default on every version of Windows.
  2. #52
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Great to know that....Thanks
    BTW, I am new here
    Welcome
  3. #53
    Jun 2006
    I have hibernation issue with the engenius wireless adapter. Strange because when I use my laptop coming in and out of hibernation is ok but when I use carpc it cannot go hibernation due to the wireless card. I am using windows to manage the connection and don't have netstumbler or wifi hopper.
    Wonder whats the different between my laptop and the carpc that is causing this to happen.
  4. #54
    Apr 2007
    Don't know much about hibernation, but have you tried turning off power saving / power management options on the card? (not sure if that helps or not).
  5. #55
    Elsewhere
    nemo: I had issues when i used the included wireless administration software.
    I removed that and used the Windows Zero-Config Whatsit and the problems went away.
    How about the Wiki?
  6. #56
    Jun 2006
    I did not use the software that came with engenius. I just plug it in a USB port and windows auto detects and installs the driver. Not sure if this is Windows Zero-Config Whatsit. I did the same thing on both my laptop and my carpc. My laptop was able to go into and out from hibernation flawlessly but the carpc however failed to go into hibernation, it says the wireless ....is preventing windows to go into hibernation. I did not use RR for hibernation, only used windows hibernation only. Any idea?
  7. #57
    Apr 2007
    Quote Originally Posted by nemo1 View Post
    Oh I was wrong, it looks like the same box is used for both 362 and 862, that is why it says A/B/G on the box. It has a check box on the bottom of the box that shows that model it is. Either way the one you got is good.
  8. #58
    Jun 2006
    IC...thanks for the info.....
    Thats the most important....
  9. #59
    it appears the 362 is on sale.. ordered that with the 7dbi omni...
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  10. #60
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    I've got a problem. I ordered the engenius 362 from newegg and it has yet to come. I also ordered a 7dbi omni antenna from ebay that just came in the mail. Upon closer inspection, the connector seems to be really tiny. I think this one is call RP-SMA. Does any of you know if the engenius' SMA RF connector is compatible with this antenna? I really hope it works other wise i just wasted $13
  1. driver issues with usb to ide adapter
    By jermkesler in forum General Hardware Discussion
    Last Post: 08-31-2006, 10:09 PM
  2. Best USB Wireless Adapter?
    By James141 in forum Wireless Communications
    Last Post: 06-25-2006, 02:48 AM
  3. Head Unit USB Adapter
    By unr3al in forum General Hardware Discussion
    Last Post: 09-22-2005, 12:02 AM
  4. need power supply info for buslink pcmcia usb 2.0 adapter
    By minghi in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:54 AM
  5. Wireless Game Adapter
    By cruiser01 in forum Wireless Communications
    Last Post: 02-15-2005, 07:53 PM
