Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 100
Thread: Engenius/Senao USB Wireless adapter
  1. #61
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Yes engenius is using RP-SMA and its small. Where are you planning to place the ant that you bought. If its an external one I think its not using SMA connector. It uses N-type coonector. Maybe you can take a picture of the ant connector.
  2. #62
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    Quote Originally Posted by nemo1 View Post
    Thanks for the reply.
    This is the antenna i got:
    http://cgi.ebay.com/ws/eBayISAPI.dll...8225&rd=1&rd=1
    If the engenius is RP-SMA i'm pretty sure its going to work.
    I'm really not looking to mount the antenna outside. I think its ugly. I wonder how it'd do if i mount both the usb adapter and antenna inside the dashboard.
    btw, i just tested this antenna with my dlink pci wireless card and noticed that the signal strength of my connection did not increase much but what it did was pick up like 4 more APs around my area.
  3. #63
    Jun 2006
    Ya the engenius is RP_SMA. I tried placing the ant inside the car and I noticed that the signal is weaker.
  4. #64
    Apr 2007
    Hi,
    I also bought a rp-sma 9dbi omni rubber antenna from ebay. I noticed no difference in signal from the 2dbi antenna that came with the eub-362 ext and my new 9dbi antenna. I also noticed no difference in signal with the same 9dbi antenna on my buffalo whr-hp-g54 router. I do notice a improvement in signal with a cantenna on the buffalo router and no signal difference on the the engenius. Has anybody noticed any signal difference with the 9dbi antenna on the engenius eub-362?
  5. #65
    Mar 2007
    Nashua, NH
    You guys know that you need a ground plane under these antennas, right? They need to be mounted ontop a flat piece of metal to work properly...likt the trunk of oyu car.
    Otherwise the signal will be worse.
  6. #66
    would a plate of metal with a wire attached to it and the body do the same job?
    i plan to mount mine inside. perhaps on the rear window.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  7. #67
    Mar 2007
    Nashua, NH
    I believe so...as long as it's large enough. I don't think the metal plate needs to be wired to anything though. I would spend some time searching on the internet for antenna ground plane...or seomthing like that.
  8. #68
    Jun 2006
    Quote Originally Posted by madmax00 View Post
    Hi,
    I did notice a signal difference between stock ant and the 9dBi rubber duck ant. I am able to get stronger and more ap's with the 9dBi.
  9. #69
    Apr 2007
    Thanks, nemo1 for your reply.
    This antenna is a a rubber duck antenna. The seller on ebay calls the antenna 9dbi omni.
    http://www.data-alliance.net/servlet...Wireless/Detai
    I do not think that I would need a ground plane with this type of antenna? I notice no difference in signal with this antenna. If I place the antenna next to my ear and lightly shake the antenna it rattles like something is loose or broken inside the antenna. I was wondering if the antenna is broken. I wrote the seller on ebay twice and he will not reply to my emails. l will not buy from him again and I am ready to leave negative feedback.
  10. #70
    Feb 2007
    ARE THESE EXCESS???????/
    ENGENIUS TECHNOLOGIES ECB-3220 Wireless AP / BridgesView Pic EnGenius ECB-3220 802.11g High Power 400mW Wireless AP/Bridge/WDS w/ Removable Antenna - Retail
    Antenna: TNC Type Female Reverse
    Channels: 11 for North America
    Data Rates: up to 54Mbps
    Device Management: Web-based configuration HTTP Telnet configuration SNMP V1/V2C MIBI, MIBII
    Frequency Band: 2.4–2.484GHz
    Receiver Sensitivity: -94dBm @ 1Mbps -92dBm @ 2Mbps -89dBm @ 5.5Mbps -86dBm @ 11Mbps -92dBm @ 6Mbps -90dBm @ 9Mbps -88dBm @ 12Mbps -86dBm @ 18Mbps -83dBm @ 24Mbps -79dBm @ 36Mbps -74dBm @ 48Mbps -72dBm @ 54Mbps
    Security: IEEE802.1x Authenticator/RADIUS Client EAP-MD5/TLS/TTLS support in Access Point Mode WPA/Pre-share Key(PSK)/TKIP MAC Address Filtering Hide SSID in beacons Layer 2 isolation
    Standards: IEEE802.11b, IEEE802.1x, IEEE802.3, IEEE802.3u, IEEE802.11g, IEEE802.11b/g
    Model #: ECB-3220
    Item #: N82E16833168017
    Return Policy: Limited 30-Day Return Policy
    In Stock
    $6.00 Mail-In Rebate
    3 Business Day Shipping $6.43
    [2 Reviews]
    Move To Wish List $129.99
    ($123.99 after $6.00 Mail-In Rebate)
    ENGENIUS TECHNOLOGIES ECB-8610 Wireless AP / BridgesView Pic EnGenius ECB-8610 802.11a/g High Power 400mW Wireless AP/Bridge/WDS w/ Removable Antenna - Retail
    Antenna: External Antenna
    Channels: 802.11b/g: 11 (North America) 802.11a: 12 non-overlapping channels (North America)
    Device Management: Web-based configuration (HTTP) Telnet Configuration SNMP V1
    Frequency Band: 802.11a: 5.15-5.25GHz, 5.25-5.35GHz, 5.47-5.725GHz, 5.725-5.825GHz 802.11b/g: 2.4-2.484 GHz (USA)
    Receiver Sensitivity: 5.15~5.85G(IEEE802.11a) 6Mbps@ -88dBm; 54Mbps@ -70dBm 2.412~2.472G(IEEE802.11g) 6Mbps@ -91dBm; 54Mbps@ -74dBm 2.412~2.472G(IEEE802.11b) 11Mbps@ -90dBm 1Mbps@ -95dBm
    Security: IEEE802.1x Authenticator / RADIUS Client (EAP-MD5/TLS/TTLS) Support in AP Mode WPA/WPA2 supplicant support in Client Bridge mode WPA2/WPA / Pre-share Key (PSK)/ AES/TKIP MAC address filtering (AP mode) Hide SSID in beacons
    Model #: ECB-8610
    Item #: N82E16833168026
    In Stock
    $10.00 Mail-In Rebate
    Free 3 Business Day Shipping
    [1 Reviews]
    Move To Wish List
  1. driver issues with usb to ide adapter
    By jermkesler in forum General Hardware Discussion
    Last Post: 08-31-2006, 10:09 PM
  2. Best USB Wireless Adapter?
    By James141 in forum Wireless Communications
    Last Post: 06-25-2006, 02:48 AM
  3. Head Unit USB Adapter
    By unr3al in forum General Hardware Discussion
    Last Post: 09-22-2005, 12:02 AM
  4. need power supply info for buslink pcmcia usb 2.0 adapter
    By minghi in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:54 AM
  5. Wireless Game Adapter
    By cruiser01 in forum Wireless Communications
    Last Post: 02-15-2005, 07:53 PM
