Results 1 to 3 of 3
Thread: 12v external wifi
    Jul 2005
    12v external wifi
    Hi,
    I have an xbox as my carpc. So unfortunately its not as versatile as a normal pc.
    I want to add wifi capabilities to it so that I can avoid taking it out every time I want to copy more music onto it
    The xbox can't use a PCI card or a usb wireless adaptor. ( that I know of )
    So the option remaining is to use the LAN port from the xbox to an external wireless access point. I dont want to use an inverter, which means Im going to power it off 12v.
    Is there a WAP that can be run off 12v natively ?
    If not, would it be hard to chop up the standard power adaptor and feed 12v into it ?
    Could I feed that power from my 12v power supply ? The xbox is powered by a 90watt M1-ATX power supply
    Thanks, your advice is appreciated
    Low Bitrate NickFury's Avatar
    Nov 2004
    Worcester MA
    Microsoft made an 802.11g external wifi card for it.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Dogo
    Hi,
    You can try and find one of these http://www.tigerdirect.com/applicati...578&CatId=1594
    They call them ethernet bridges.
    As for powering it, with out seeing the actual unit, it is hard to say. It might be a 12 volt unit, but I think it is probably less voltage. You might be able to get the voltage from the M1, or you might need a voltage regulator to get the right voltage. The chances of it being more then 12 volts is slim, so powering it in your car should not be thatmuch of an issue.
    Michael
  1. USB wifi with external antenna?
    By Micke in forum Wireless Communications
    Last Post: 07-05-2005, 01:56 AM
  2. Replies: 10
    Last Post: 01-21-2005, 05:27 PM
  3. External WiFi Receiver w/ Ethernet Port?
    By VanMan69 in forum Wireless Communications
    Last Post: 10-18-2004, 12:31 PM
  4. 3A 12v regulator?
    By hcker2000 in forum Power Supplies
    Last Post: 10-15-2004, 02:46 PM
  5. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 01:33 PM
