Results 1 to 7 of 7
Thread: widcomm bluetooth problem
    Feb 2006
    uk
    Question widcomm bluetooth problem
    Hi
    Ive just installed widcomm 4.0.1 software. It seems to work ok but I have a network cable disconnected icon for bluetooth network in my system tray. Im running XP pro sp2. Does anyone have any suggestions?
    Bobble
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    riiighhhtt
    肚子笑痛了
    S60 Install
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Quote Originally Posted by Bobble
    Hi
    Bobble
    The network cable disconnected icon appears when a network card is enabled but receives no signal.
    To stop the service (and remove the icon)
    Right-click the offending icon and select the option
    <Open Network Conections>
    Then find the bluetooth network icon, right-click it and select <Disable>.
    If you want to use this network later simply right-click and select <Enable>
    To find it at a future date try <Start> <Control Panel> <Network Connections>
    It would equally be possible to leave the card enabled and remove the icon, but I feel it's better to know what network connections are open and closed for basic security.
    I hope that helps.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    When you install the widcomm driver it lets you setup a bluetooth network and adds in a bluetooth network connection..... so unless you're going to use it (like to network two computers together over bluetooth instead of a normal LAN or wifi, or network with a pocketpc) then just disable it and be done.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Dec 2005
    Raleigh, NC
    Right Click on "My Network Places"
    >properties
    Right Click on the specific network connection
    >properties
    In the general tab make sure the box circled below is not checked.
    I don't have my bluetooth adapter plugged in now, but it's the same box.
  1. Bluetooth Dongle Not Working correctly
    By KingsDude in forum Wireless Communications
    Last Post: 05-17-2007, 02:30 PM
  2. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  3. Weird problem with Nokia PC Suite and Bluetooth
    By Rafster in forum Wireless Communications
    Last Post: 06-12-2005, 04:41 AM
  4. Bluetooth to FM Solution Needed
    By Pewterbird in forum Wireless Communications
    Last Post: 05-16-2005, 02:28 AM
  5. mobile action usb bluetooth device & WIDCOMM 4
    By cyclops in forum PhoneControl
    Last Post: 04-29-2005, 05:57 PM
