Results 1 to 6 of 6
Thread: Bluetooth question V710 phone
    Jan 2006
    New Jersey
    I have a Motorola V710 phone, when I do a service discovery with my bluetooth software the only service that shows up is Bluetooth DUN, and it works. However the other services like file transfer and serial port service show up as service not available. Is this because of the phone? I edited the seems to allow file transfer and bluetooth. Does anybody know?
    Oct 2004
    NY
    is it with verizon?, I know they lock down some services to force you to use there transfer method$
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    no serial avail on that phone.. but if you use phoco you can use the port created by DUN.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by tbird7
    Unless you hack the phone, you only get DUN and headset/hands free profiles. If you know enough about hacking the phone, seem editing, etc. you should know that this board is not the right place to get that question answered. Goto Howard Forums or Phonescoop.
    ~Jimmy
    Jan 2006
    New Jersey
    I am trying HOFO also. The main reason I posted here is because I am trying to get Phoco to work with my carputer. When I run the Phoco phone test app it looks like it is working, however when I run the actual phocp app it opens up but there is no phone info there. I have been trying the Phoco forum, but for some reason I can't read the text in that forum. I like it here better anyway.
    Woodbridge, VA
    Blog Entries
    55
    use the port that DUN creates and phoco will work.. limitedly. Create a dial up connection on the phone... disconnected.. then run the phone test on that port. It will work.
  1. Bluetooth phone control
    By 65coupei6 in forum Newbie
    Last Post: 08-12-2005, 05:47 PM
  2. Using Windows as handsfree with Bluetooth Dongle and BT enabled phone
    By Blassox in forum Wireless Communications
    Last Post: 07-26-2005, 05:17 AM
  3. phone mute by bluetooth
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 03-09-2005, 06:40 PM
  4. Any Bluetooth experts here?
    By sygad in forum Wireless Communications
    Last Post: 10-11-2004, 07:08 AM
  5. sony ericsson phone bluetooth pc remote
    By streetknight in forum Input Devices
    Last Post: 03-20-2004, 05:44 AM
