Results 11 to 20 of 22
Thread: Cingular and Razr v3 and PhoCo - Good Combo?
  1. #11
    FLAC alti's Avatar
    NY
    maybe he did not disable his cable modem
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  2. #12
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by alti
    nah, at those speeds, it's probably DSL.....
    Peace,
    Rafster
  3. #13
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Was that 230kbps on an online speed test? You can't go by what the little connection icon on the taskbar says b/c that's the "serial" connection between the computer and phone.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
  4. #14
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by nkotch
    Yeah, Kind of like my UPNP internet connection in My Network Places says I have a 100MBPS connection....
  5. #15
    Dec 2005
    my cable modem was disconnected....but if u can link up that online speed test ill try again tonight and post what it says the speed is.
  6. #16
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    Quote Originally Posted by wesniles
    http://reviews.cnet.com/7004-7254_7-0.html
    is ok
    I got 1670.1 kbps from work just now
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
  7. #17
    Jan 2006
    MN
    are you using cingular's connection manager? if so you could have the "accelerator" turned on, which all that does is degrades the quality of images
    Josh
    '04 WRX
  8. #18
    Dec 2005
    FL
    Yea, try that online speed test and let us know. I usually only get like 70kbps or so on my V551, which is slower than what I feel it should be at.
    Also.....try one test using the phone over bluetooth and another using it with a serial/usb cable and see if there's much of a difference if you are able to.
    Nick
  9. #19
    Dec 2005
    Why couldnt you utilize a BT connection to your phone and Motoral Phone Tools to control the phone? I havent tested actual talking over the PC with my RAZR connected but have dialed out with it and then used the handset to talk.
    Motorola PhoneTools will simulate your phone on the screen and give you the advanced functions for data transfer and syncing to your Calendar/Outlook/Etc while offering the usual phone functions on screen.
    If my RAZR wasnt dead I'd play with it but I'm waiting for Cingular to let the RAZR v3c out in mass before I replace mine as I want the upgraded camara and transflash slot.
    ~Kris
    [1995 Nissan 240sx]
    Planning.........[::::::::::] 90%
    Parts.............[::::::::::] 60%
    Construction...[::::::::::] 10%
    Software........[::::::::::] 50%
    [1994 Mazda RX-7]
  10. #20
    Dec 2005
    FL
    Does motorola phone tools do all that (phone control, audio routing, dialup access) all at the same time over a single bluetooth connection? I think that would be where the problem is.
    Nick
