Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Cingular and Razr v3 and PhoCo - Good Combo?
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    The title pretty much says it all... MEdiaNet Unlimited, Razr V3 (black or silver?) and PhoCo (in RoadRunner)... good combination? I just want a small phone that will work from my pocket. I've got a dlink usb bluetooth adapter ready and waiting. I want to get in the car and be able to talk to the microphone attached to the computer and hear the calls on the car speaker. caller id, voicemail notification on the screen, etc. I don't want to have to take the phone out of my pocket and plug it into usb (it's just too much of a slam on the cool factor scale).
    This will give me roaming internet access? How difficult is it going to be to get the cingular internet access to cohabitate nicely with the regular roaming wifi?
    Your thoughts and input are appreciated.
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Do a little search for the Razr and phonecontrol as I know it's talked about a good bit already. I have the v551 and I think both these motorollas only support 1 bluetooth connection at a time, so it's kind of a "workaround" how phonecontrol works with it. Took a little tweaking but I got it to work with mine, but what it does it connect to your phone (bluetooth) over a serial bluetooth connection to control the phone and let you know when you have the call, if you take the call on the screen then it drops that bluetooth connection and reconnects to the phone over a handsfree/audio gateway connection so that audio is routed through the computer.
    It works, but at least for me it was never 100% stable. Sometimes it wouldn't reconnect to the phone, or sometimes I couldn't hang up from the screen, etc... If I go back to using it I'll just use it control the phone and just use the phone itself or a wired headset.
    I've got the same medianet plan it works fine with dialing up to get on the internet, not very fast but enough to check simple sites out or check email or something. Only thing is that since the phone only does 1 bluetooth connection at a time then phonecontrol will have to disconnect in order for you to dialup through it.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    I wouldn't do it. The Razr isn't going to give you much more than dial-up speed.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    Jan 2006
    MN
    go nokia 6682, it can support of to 5 bt connections at one time.
    Josh
    '04 WRX
    Sep 2005
    CT
    Thanks, this is exactly the sort of response I'm looking for.
    I'm working very hard (due to wife's insistence) on not buying more than I need... although sometimes I fail miserably... like who needs an athlon xp 64 in a car? Despite that failure, I'd like to get the minimum phone possible. Frankly, I hate talking on the phone and any of the PDA features I'd just do on my car anyway. Is there any practical way to find out which of these phones support multiple bluetooth connections? I don't think the PhoCo compatibility chart is very up to date, either.
    If I stick with Cingular, it looks like the Samsung D357 is the cheapest BT phone (and it has EDGE). But I can't find, either on Cingular or Sammy's site any information about the number of BT connections you can have (despite flipping through the 210!!! page user guide. And obviously it's nowhere near as cool-looking a phone. Oh, and Zorro from PhoCo says "I don't think so. Samsung phones are pure crap, concerning the AT-Command Interface. Never saw one working without any problems." So maybe I shouldn't be looking at Sammy with PhoCo...
    Maybe I should ask the question the other way... starting with the phone, what's the coolest phone I can get that (i) has multiple bluetooth connections, (ii) is compatible with a carrier that has high speed (ish) internet access, and (iii) doesn't have a load of features I don't need? Then I can go on ebay and buy an unlocked one or find a package from the provider.
    Thanks again
    Worklog: http://www.mp3car.com/vbulletin/showthread.php?t=65059
    Now with pictures!
    Jan 2006
    MN
    Quote Originally Posted by randomjohn
    Thanks again
    With all those features, i dont think there is a phone that wont have the extras you dont need. those are top of the line features. From that criteria with cingular i think the 6682 is the only phone; somone please correct me if i am wrong. I would say get teh z520a but it only connects thru gprs. Check out www.phonescoop.com to get most feature on the phones.
    Josh
    '04 WRX
    Dec 2005
    FL
    From when I switched I looked at getting that 6682 and it seemed like a great phone. When I was ready to get a new phone they were having some issues with the firmware on that one so I couldn't get it but I think that's been worked out? You should jump over to http://www.howardforums.com/ and do some searches on some of the Cingular phones.
    Nick
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Go with a Moto V551/V557 or Samsung D307/D357
    All 3 give you Edge speeds and BT and are WAAAAAAAY better than the Razr... IMHO
    Peace,
    Rafster
    P.S. I used to have both a V551 (It was stollen ) and a RAZR.... I would love to get another V551/V557, but I'm happy with my Nokia 6620
    Dec 2005
    i just connected my cingular RAZR to my computer via the usb cable and was able to get 230kbps.
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by wesniles
    Hmmm, how did you manage that? Razr is GPRS Class 10....
    http://www.phonescoop.com/phones/phone.php?p=547
    http://www.mobile-phones-uk.org.uk/gprs.htm
