Results 1 to 10 of 10
Thread: 2 WiFi over 1 antenna?
    Jan 2006
    I intend on installing 2 wireless adapters in my car (running 802.11b/g).
    One will be a modded WRT54GL and the other a normal PCI WiFi card.
    Will I need two seperate antennas for these, or can I split the antenna cable and use it for both adapters? If I can use one only, do I need an amplifier?
    Thanks in advance.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by royandrews
    Thanks in advance.
    You can use an isolator/combiner, but it is not worth the cost considering that most cards don't need an antenna, and that WIFI antennas are pretty cheap.
    As for the look, well, you can do it with an isolator/combiner, but the cost is just not worth it.
    Michael
    Elsewhere
    I'm dying to know....
    What's the point of multiple WiFi adapters?
    How about the Wiki?
    Jan 2006
    The point of two is one is a Kismet Drone and the other is a normal WiFi card so I can run Kismet and Netstumbler at the same time.
    Jan 2006
    Sorry for the double post, but the forum won't let me edit my other post.
    Anyway, I've decided to put 2 WiFi antennas on top of my car, but I want them to look neat. How close together can I put them? Will putting them with the bases almost touching mess up the signal?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah be careful. if they are too close they will spark and blow your car up
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Scouse Monkey
    He is playing.
    There is no problem putting them close together, HOWEVER, if one is transmitting it might "wash out" the other antenna if it is receiving. In general, you want at least a wavelength between antennas. Since this is 2 ghz, a wavelength is on the order of about 1.5-2.00 inches.
    Michael
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    I always hoped that as they're microwaves I could warm up a bacon sarnie with them...
    Tainted Love Cris's Avatar
    Romania
    Jan 2006
    Quote Originally Posted by Wiredwrx
    ...you want at least a wavelength between antennas...a wavelength is on the order of about 1.5-2.00 inches.Michael
    Sweet. That's the kinda gap I'd have anyways.
    My DIY housing is gonna be one of a kind. The GPS will not be an antenna, but rather the actual unit. The bottom of the housing will be open for magnetic mounting to car roof (base plate). There will be rubber seals around the edges of the bottom. Please point out any things to change.
  1. Recommend WiFi card and Antenna?
    By DaveB in forum Wireless Communications
    Last Post: 01-24-2006, 11:04 PM
  2. Adding external wifi antenna to ibook
    By daj100 in forum MacCar
    Last Post: 12-12-2005, 02:17 PM
  3. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 06:43 PM
  4. WiFi Antenna w/ 1W amp through Tint.
    By SKiTLz in forum Wireless Communications
    Last Post: 11-10-2005, 10:49 PM
  5. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 08:11 PM
