Results 1 to 10 of 11
Thread: Belkin CableFree USB Hub
    Low Bitrate baudi's Avatar
    Feb 2006
    Arlington, VA
    This looks very interesting: a cable-less USB Hub from Belkin.
    Dec 2005
    perfect for a carputer environment
    Newbie Drake69's Avatar
    Feb 2006
    Richmond, VA
    Yeah, but you gotta remember, cablefree or "cold" hubs don't always work with all USB connections. The problem with cold hubs is they rely on the same power outlet that your PC is using, which is perfect for directly connected devices, but there is a limit to how much you can connect up. Powered or "hot" hubs that plug into a separate power source are guaranteed to run all USB devices, no matter how many are connected up.
    Think of it this way:
    PC <--> USB device = 100% power to that port.
    PC <--> USB cold hub = 100% power to that port.
    cold hub <--> USB device = 25% (dividing power)
    PC <--> USB hot hub = 100% power to that port (not needed).
    hot hub <--> USB device = 100% (supplied directly)
    A cold hub might work with two devices if they don't demand too much power from the hub, but three or more would be pushing it, causing problems with one or all the other devices already connected. Low-yield devices like memory cards or single mem-card readers would be okay, but USB Notebook harddrives would not work if at all.
    The club I belong to: FM2CD 4X4 Club
    My Personal Page: Links4Jeeps.com
    Feb 2006
    Arlington, VA
    I think you misunderstand this product. It's not a cold hub. It's a wireless hub. It communicates wirelessly with the USB dongle, and provides 4 USB ports in a remote location. It is plugged in to its own power supply, so it should be able to provide full power to each port.
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    Why poop on his party ? I'm sure to him it sounded like he knew what he was talking about!
    "cablefree or "cold" hubs...."
    Think about it.. a wireless hub would HAVE to be plugged in or be powered somehow. So, using some common logic, it would definetely be a "powered hub", which is the correct term to use!
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
    Aug 2004
    what is a cold hub?
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    A battery attachment would be KEY!
    And for the record.. I'm running Wifi, Touchscreen, GPS, 1GB USB Stick off a 'cold' hub.. well actually i suppose my hub is 'lukewarm' because it uses two usb ports.
    Very cool device. I dont need/want one in my car but the mention of such a device for a media center pc is a good idea (putting it near the sofa for plugging in controllers, usb sticks, cams, etc...)
    Whats the speed like? I have not heard of the specs on ultra wide band.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Feb 2006
    Arlington, VA
    UWB Speed
    Ultra wide-band operates at different speeds depending on the application. 100 Mbps to 220 Mbps implentations are common, and 480 Mbps to 1 Gbps are possible. So it's fast -- similar to Ethernet speed.
    Feb 2006
    Arlington, VA
    Belkin Shows Wireless USB Hub with UWB at CES
    http://www.wifinetnews.com/archives/006201.html
    By Glenn Fleishman
    Belkin didnít have a working demo, but did have prototypes of its recently announced ultrawideband (UWB) based USB hub: The hub comes with a USB 2.0 dongle that plugs into any USB port and bridges to the USB hub within a few dozen feet. No special software or drivers is required to use either the dongle or the hub. A Belkin spokesperson at CES confirmed that these devices will run at 110 Mbps, with future models reaching the full 480 Mbps of both UWB and USB 2.0, and that they are sold only in matched pairs.
    The matched pair issue is a small problem because it means that you cannot have multiple dongles associated with the same USB hub (which might confuse USB devices, but could work like a USB switcher, too), nor can you associated multiple hubs with a single dongle, nor mix and match hubs and dongles. This will change in future releases, Iím sure, as all of the UWB vendors interested in USB 2.0 replacement want to offer users as much flexibility as possible.
    Jul 2005
    Michigan
    I bought one of these the other day to give it a test. The advertised range is stated as up to 30 feet. I did not have much success with this range. However when connected the device worked great. 30 feet seems great if it would get there.. had more luck with the 15 to 20 foot range.
    Anyone else tried it?
  1. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 06:57 PM
  2. USB Audigy 2 NX, D-Link USB Hub, and 15 W POL
    By Caelric in forum Power Supplies
    Last Post: 01-17-2006, 01:02 PM
  3. Replies: 6
    Last Post: 12-27-2005, 02:41 AM
  4. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  5. USB HUB Powering
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 08-18-2005, 08:25 PM
