Results 1 to 9 of 9
Thread: Having problems setting up ad hoc network.
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I'm trying to set up an ad hoc network so I can connect to my carputer from work while it's parked..
    I am able to get connected to it but I can't ping it for some reason..
    I don't have a firewall on either machine. Any ideas?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    What address are you using to ping? I've always had issues with Ad-hoc with regard to reliability. The standard just doesn't seem to be very mature unless you know what you are doing.
    Here's what I usually do. Go into Network Connections and go to properties for the wireless adapter. On both machines, set the IP manually (192.168.0.x or whatever suits you), and subnet of 255.255.255.0. On one machine, leave default gateway and DNS servers blank. On the other machine, set those fields to the IP of the other computer.
    I eventually realized that 80% of the time it took to establish a connection was because of IP. It's a lot more forgiving when set manually. Let me know if this improves your condition.
    Oct 2003
    Poland, OH
    The reason it takes so long if your using DHCP is because if your not running a DHCP server on the PC your connecting to then the client won't get an IP address.
    What I do is go into the wireless network connection properties, tcp/ip properties, alternate configuration. There I assign an IP address of 192.168.40.5 on machine "A" with a subnet of 255.255.255.0. Then on machine "B" I do the same thing except assign it 192.168.40.7.
    This way.. When I want to connect to a WAP I don't have to go back in and change the settings to DHCP so it can connect to it.
    This way works and I can get connected I just can't ping for some reason.
    Dec 2005
    Dayton, OH
    So both machines show 'Connected' with an IP?
    Oct 2003
    Poland, OH
    Yes, both machines show connected and use the IP's I configured in the "alternate configuration."
    Dec 2005
    Dayton, OH
    I just tested that config and it works fine, although the IP still takes awhile to pop up. But they ping fine, and as soon as its connected. Are you pinging by IP address instead of computer name? Check again to make sure they are on the same subnet and the first three fields in the IP are the same.
    Oct 2003
    Poland, OH
    Yes, I ping by IP address. Yea, I know it works. I had that setup on two laptops and it worked fine. Just can't get it to work with carputer and laptop.
    Dec 2005
    Dayton, OH
    Both using the same encryption/password? Try retyping it. All proper protocols installed and checked in the adapter properties? I'm just throwing out ideas now. If both cards show strong, unfaltering signal then I'm a bit stumped.
    As a test you might want to disable your other network adapters, then connect and test ping. I've had issues like that before...
    Oct 2003
    Poland, OH
    I'm not using any encryption as of now.. I want to get it working first.
  1. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  2. Wireless G - Wire'd Network Problems (Remote Desktop)
    By nFiniteTuning in forum Wireless Communications
    Last Post: 01-01-2005, 07:34 PM
  3. Network problems... tech support
    By cadence117 in forum Wireless Communications
    Last Post: 04-30-2004, 04:30 AM
  4. Network problems... tech support
    Last Post: 04-20-2004, 06:47 PM
  5. Replies: 5
    Last Post: 06-28-2003, 05:20 AM
