Results 1 to 7 of 7
Thread: unable to connect with my phone
    Banned
    Nov 2004
    I just spend last 5 hrs trying to fig out the phone control.
    I am still under construction so I am trying this on my laptop and desktop. Phone control finds my Razr V3 but no contacts are pulled to the program, unable to dial, recieve or SMS
    I even bought another Bluetooth adapter but no luck.
    I also tried with usb cable that I use to sync with my Razr for Motorola Phone tools.
    Any sugestions?
    Greg
    Chicago
    Banned
    Nov 2004
    Is there anyone that got the phone connect to work?
    I've been working on this for few days and I am pretty good wit PCs and all the tech stuff.
    I got to the part that I can get my pc to act as a handsfree device thru bluetooth but within the Centrafuse software the most I ever got was that it was displaying one (1) sms message.
    No contacts or talking thru the PC.
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    Greg
    Variable Bitrate DaveB's Avatar
    Mar 2004
    I did extensive debugging on this and I figured out how to get the Razr V3c to work with phoneco. The problem is your USB drivers.
    I used hyperterminal in windows to send modem AT commands to the motorola phone and I discovered that what happens is the AT command to retrieve the phone directory from your phone times out.
    To fix this, you'll want to go into "my computer/hardware/device manager" and remove your current USB driver. Then plug your phone in using a USB cable. When it auto-detects, force it to use the USB drivers I've attached to this post.
    In phoneco, select E815 as the model of phone that you are using.
    Attached Files Attached Files
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Aug 2004
    Lancaster, Ohio
    Will the driver you posted work for the e815?? I am having problems connecting my 815 by usb...
    Mar 2004
    I don't know. I don't have an E815. The driver is, I believe, for all motorola phones though so you could give it a try.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Banned
    Nov 2004
    ok but what if I'm using bluetooth????
    Oct 2007
    any updates did anyone ever get this to work?
  1. Wow, that's fast!
    By tom2112 in forum GPS
    Last Post: 01-02-2007, 01:28 AM
  2. Verizon fried my phone!
    By blurp in forum Off Topic
    Last Post: 04-16-2006, 03:02 PM
  3. Need help with cell phone choices!
    By tom2112 in forum Wireless Communications
    Last Post: 01-20-2006, 03:28 PM
  4. Bluetooth recamendations
    By djchicago in forum Wireless Communications
    Last Post: 01-11-2006, 01:00 AM
