I take it you mean you can make phone calls via the phone? Your phone can maybe only make limited bluetooth connections if this is the case. Some phones work ok doing this some dont, some dont even work right with phoco on its own as it uses 2 connections audio gateway and com port connection which is probablt what your internet is trying to use. You could try creating another port in BT manager and getting one or the other to use that instead.
LinkBack URL
About LinkBacks
