Results 1 to 5 of 5
Thread: Info: Wifi Receivers/Antennas
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    i was thinking we should start a thread of wifi receivers/antennas everyones using so people can have a quick way to get the best for what they are looking for.
    Product name:
    Price:
    Usb/pci/pcmcia:
    Specs:
    Est. Range:
    Review:
    Rate (1/10):
    how about it everyone?
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    My NIC is a Linksys WMP-54G
    The Antenna:
    Model # - Radiolabs Model: "2.4mobile-7"
    Frequency Range 2400 - 2500 MHz
    VSWR <1.5 @ 100MHz bandwidth
    Impedance 50 Ω
    Gain 7.8 dBi
    Polarization Vertical
    Max. Power input 50 Watts
    Ground Direct Ground (RF chassis ground with mag-mount)
    Connector type RPSMA, MC-Card, MMCX, RP-TNC, N-Female
    Dimensions 12" tall
    Weight 1.5 pounds
    Maximum wind velocity Will stay on metal roofed vehicle at any speed!
    Radiator Material Stainless Steel hardware, UV resistant magnetic mount base
    It actually stays on the car at speeds > 90mph. If you brush against it's pretty easy to knock off, though. GREAT reception. I'm getting 5 bars now from my home router where before I was lucky to get 1.
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    I use
    Model: EUB 362-Ext
    Price: $68 + Shipping from HauteSpot on eBay - Can probably be found cheaper but I had an eBay GC.
    FEATURES
    • Data Rates up to 108Mbps (in Super G mode) for maximum throughput
    • High Output Power up to 200mW (23dBm)
    • Support for External Antenna
    Link to PDF with the rest of the technical specs: http://pcomaha.com/EUB-362EXT.pdf
    This thing is absolutely amazing. I find more AP's than with any of my other wireless cards/antenna combos. The external antenna support is also a big plus as you can add a higher gain antenna and improve your range even more. I haven't had time to do any distance testing yet but intend to this weekend.
    ATVMS.com
    Jul 2004
    Santa Barbara, CA
    ttt
    could we sticky this? I'd like to see what other people are using, and i think this is a pretty FAQ so it'd help many people.
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  1. WiFi FAQ
    By jrtf83 in forum Wireless Communications
    Last Post: 12-30-2009, 07:16 PM
  2. WIFI CONNECTION MANAGERS (mini review)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-27-2007, 09:04 PM
  3. Good WiFi antennas? Reviews / info
    By xbi0s in forum Wireless Communications
    Last Post: 02-27-2006, 11:33 PM
  4. Recommend WiFi card and Antenna?
    By DaveB in forum Wireless Communications
    Last Post: 01-25-2006, 12:04 AM
  5. File Info / Movie Info
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 05:42 PM
