Results 1 to 5 of 5
Thread: ppc-6700 and blue tooth teathering
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    Anyone here provide me a walk thru, on getting internet access thru bt with the ppc6700?
    this is what i've tried
    on the pc:
    created a modem connection using the com port provided thru BT,(generic 33.6)
    turned off all flow control
    created a dial up networking connection for my carrier(alltel, #777 no password/un required)
    on the PPC:
    kill activesync
    run wmodem, set it to run on BT
    overview:
    pc keeps erroring out when trying to connect, something about hardware errors.
    any ideas?
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Apr 2006
    Hello, I have the ppc-6700 and use it to dial up by connecting to a d-link usb bluetooth donge in my car setup and a billionton pcmcia bluetooth card on my laptop i use everyday.
    It seems like you're making it more complicated than necessary here's what I've always done...
    1. Pair the devices
    2. Discover services on the phone from the computer. Dial up networking should appear.
    3. Connect to the dial up networking service and a window should pop up prompting for phone number, uname & pw.
    For my phone leaving username and password blank and using #777 works fine. I've never had to disable activesync or use the wireless modem app. I have installed the driver and used the wireless modem app over usb to see if it granted any increase in speed but I did not notice a difference. I don't have evdo service in my area. I'm sure if I would want to use the usb connection to maximize the speed if I did, but with 1xrtt bluetooth is fine.
    May 2005
    Elizabeth City, NC
    Quote Originally Posted by djaybake7
    1. Pair the devices
    i have no dial up network on the services screen.
    also, can you check a registry key for me? conserning the ##feature crap cuz i need the program name and command line for it, as mine does not aparently have it,
    \hlkm\services\phoneext\keyprogram\
    should be some keys# and some Prog#
    can you post data the one for #3328879 ?
    i think i have bt dun disabled(thanks alltel) and need to turn it on using that command, but i don't have that one in programming
    i have:
    #778 epst
    #33284 fieldtrial
    #3424 - dmrouter
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    Apr 2006
    I checked under keyprogram.. here's what I have..
    Prog0-7: EPST.exe followed by # and numbers
    Prog8: FieldTrial.exe
    Prog9: DMRouter.exe
    #3328879 is not listed on my phone. Let me know if I'm looking in the wrong place or not understanding the question.
    Note: I just updated the rom to include AKU2 so that could be why what you're asking for is not there. Perhaps this update would work for your device as well and add DUN support? The link can be found here ---> http://www.pdaphonehome.com/forums/s...ad.php?t=68618
    May 2005
    Elizabeth City, NC
    thanks will look at that later on today when i get home from work
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
