There are transceivers available but they require you to crack the case and hook the external antenna to the PC board. HOWEVER, I just bought a new transceiver for my Apple iBook that works via a proximity effect and it works great! You can also remove the 2db antenna and add other external antennas via an RP-SMA connection, including running a cable outside the car to a roof mounted antenna. Check with them to see if the unit is compatible with your PC (retails for $200 but you can find it elsewhere for less online). Here's the link:
http://www.quickertek.com/
LinkBack URL
About LinkBacks
