Hello All,
I have a question that maybe someone here could answer. I want to get CDMA2000 1x or CDMA2000 EV-DO internet access in my car, so I'm going to buy a module that supports both, anyways, I was wondering, if I buy the module, and get a 10min prepaid cellphone plan with a $5/month "unlimited mobile browsing" feature, unlimited as long as you are in the 1x coverage area, otherwise you only have 100 minutes (+$0.25/minute thereafter), on a simcard or whatnot, do you think I would just be able to access the internet, or would I have to get a data plan in order to do that. The module will be connected to a microcontroller, from which I will issue AT commands to the module, and I am assuming that the module I am going to get will work like the GM862 or Trizium GPRS modules from Sparkfun where I can just issue an AT command with a url and it will return the html etc.. But I dont know if I need to get a data plan or if I could use the prepaid idea. If anyone knows if this would work, could you let me know? because data plans are expensive in my area, the GTA (Greater Toronto Area).
