Page 13 of 48 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 475
Thread: Boost mobile?
  1. #121
    Newbie Simy's Avatar
    Oct 2005
    Tampa, Fl
    Possible Linux - Iden Solution? Question.
    I've been googling my ***** off trying to find a linux - iden solution, I think ive found it. However I dont have the phone yet so, Could sombody who has linux please tell me if this works? There was a brief mention of this before, but nobody posted the end result. I'm hesitant to get a phone for an operating system that im not likley to use!
    Heres the link: Click Me!
    Motorola iDEN / Nextel data service
    Unfortunately, CDPD service sucks around where I live, so it has been necessary to set up an alternative. I have a Nextel phone, and for an extra $10/mo and the price of a serial cable, I can make data calls. Unfortunately, Nextel isn't an ISP, so you need to either set up a modem to dial into or have a dialup ISP account. Also, the calls are at 9600 bps, which is actually less bandwidth than CDPD. My experience, however, has been that the reliability has been higher and the latency is actually much lower. Lastly, and most significantly, the calls are billed exactly like voice calls -- by the minute (fortunately, my plan has a lot of minutes).
    There are a couple of tricks to setting this up.
    1. Rather than counting on autobauding, you should set your phone to expect a particular speed. I use 57600, which is the top speed a Palm can do.
    2. The dial string should be set like this:
    set dial "ABORT BUSY ABORT NO\\sCARRIER ABORT NO\\sDIALTONE TIMEOUT 5 \
    \"\" ATZ OK-ATZ-OK ATE1Q0 OK \\dATDT\\T TIMEOUT 60 CONNECT"
    3. Specify the phone number as the area code and phone number (no 1 in front)
    That's about it. I used to use ucom and uvscom to talk to an IOGear UG-232A serial port connected to the phone's serial cable, but recently I upgraded to the USB cable made for the phone, which works perfectly with the umodem driver.
    Update! There's a new service offered by Nextel called PacketStream. It is a direct Internet connection (though their unmeasured service goes through a NAT gateway), so no ISP is required, and it is either unmeasured or (depending on the plan you pick) measured by the kilobyte, not the minute. I've been getting something like 20 kbps over it, so it's sort of like 1st generation Ricochet. You can also receive phone calls while using it (though it does stop data I/O). You simply dial the phone number "S=2" and you're connected.
    Thank you in advance!
    -Simy
    Carputer Status: 10%
    Have: Dell L400 (700Mhz 32?RAM, 20Gig HD), 7" Newvision, Pioneer DVDRW/CDRW via USB
    Need: Amp.
  2. #122
    Apr 2005
    Queens, New York
    I dont know if it just my phone or what but i just picked up my boost i450 and the GPS is HORRIBLE, i barely get any signal on the phone, and when i do, it isnt giving me the right location of where i am!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  3. #123
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Cheekz185
    You probably have assisted gps turned on. Turn that off.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  4. #124
    Apr 2005
    Queens, New York
    Quote Originally Posted by PURDooM
    How?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  5. #125
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I got mine yesterday and i haven't been able to connect to the net (no cable yet so i'm trying from the phone itself)
    Every time I try to access a site it give me "error 500 call you service provider" and in details it say "1019 compile error" So i call CS and they told me that is something going on with the new activations and the web bla bla bla ... so I'm going to give this POS a try tomorrow and if it does work i go to the Fricking store and buy a PCMCIA card for Verizon or Sprint and i get done with this (i have a MII so it will be perfect) the only thing is that i did want to try surfing the net with some thing cheap like this but if is no other way SO BE IT!!!!!!!!!
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  6. #126
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Thanatos, the coverage for florida is pretty good with boost. I went to Target today and picked up a boost pamphlet (is that spelt right?) And everything checks out. Looks like 20 cents a day for unlimited internet. Thanatos, let me know if you get yours working and i may buy one too.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  7. #127
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by thanatos106
    Thanatos.
    Go to a Nextel/Sprint store, and have their CS look at it..
    Mine worked tight out of the box, not WiDen, but the internet did...
    Peace,
    Rafster
  8. #128
    Jun 2005
    Anoka County, MN
    Thanatos.
    Well, you could go to sprint if you wanted to spend an extra $40 a month...
    Your situation sounds unique, perhaps the firmware in your phone is messed up. I would get it exchanged and keep the sim card if I was you.
    If you can access the AIM service, everything should work from there.
  9. #129
    Nov 2004
    Ok so finally I got this thing working (half way):
    If I go to "4.enter site" I can enter almost any site (at least the ones that are support it with a cell)
    Also I can login Msn messenger without problems.
    But if I click "google serch" I still having the same error, So querstions:
    Do you guys can search the net if you click "google search"?
    PS:the custummer service gave me some steps when trying to fix the prob and one of them is WIDEN so that this means in widen anable (no one have answer the question of how finding out if phone is widen or not)
    Thanatos.
    Nissan Aux-in MOD
  10. #130
    Jun 2005
    Anoka County, MN
    Does anyone know any touchscreen friendly DUN software? Or some API calls for DUN in windows? I usually am switching between evdo, boost, and wifi and its a PITA to do that all via connection manager.
