Page 2 of 48 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 475
Thread: Boost mobile?
  1. #11
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    WOW!!!!
    Unlimited internet in car for $6/month if that's all u use it for.....
    NICE!!!!!!!!
    Who cares if it's slow, there's no need to do any webcam freeway porn of urself getting road head.....
    I might have to pick up a boost plan...
    BTW, do you know if there is any difference in the types of phones as far as connection speeds go? For example, for GSM phones, there's GPRS (+/- 56K), then there's Edge (+/- 236KBPS)....
    Peace,
    Rafster
  2. #12
    Apr 2006
    Chicago, IL
    PurDoom:
    NexTel has a charger and USB cable in one. That's what I actually ordered on eBay but the seller shipped the wrong item. It's about $30 on the nextel site. Hopefully he'll ship the correct one and I can send this back. Either way - it doesn't seem like using the net drains that much battery - and I'm probably going to set it up so it disconnects if the net isn't in use. It only takes a moment for it to log back on and on standby the phone should last for days.
    I also set up my mologogo today - very cool!
    Raftster:
    There is iDEN and WiDEN. iiDEN is supposed to be up to ~20kbps, WiDEN is up to 120kbs I think.
    The newer more expensive boot phones are supposed to have WiDEN, however, I read that you can mod the i450 ($79) so that it can also use WiDEN. You can check out the howard forums thread about that...
    However, it seems that the i450 I recently bought at Best Buy must be already capable as I am getting speeds between 50-80kbps (the 'real world' WiDen speeds posted by many). I'm guessing that Boost Mobile must have enabled it by default as they are pitching the Boost TV and other pay per use services. That's why I was so surprised and when I first ran speed tests and began browsing the web. I've even been listening to shoutcast radio stations in my car (48kbs AAC with some buffering is perfect)
  3. #13
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Ahh, I didn't know that. I spent $5 (price includes shipping) apice for my car charger and my data cable (total $10) and plan on splicing them together. My plan is to have a 'fire and forget' solution so I can stick the phone in the car and forget its there, or wire it physically into the dash. A little display on the dash showing the cars position on a map would have a cool novelty to it.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  4. #14
    Apr 2006
    Chicago, IL
    True - I was quite surprised how good the google maps look when using mologogo and the phones are small enough to mount near/on the actual dashboard.
    If you are able to successfully splice the cables let me know - I may consider that if I can't get the actual cable I had ordered.
  5. #15
    Jun 2005
    Anoka County, MN
    This doesn't look too hard. I snapped one of the release buttons off on the data cable and used that to pry off the case. Underneath it looks like this:
    If I were to label the pins starting at pin 0 and going to pin 16, then pin 0 is black, 3 is blue, 4 is white, and 5 is red. (all corosponding to a pin on the usb cable).
    If I were to wire services into the cable, then I would connect pin 2 and and 16 to the charge cable (I bet #2 is grounded). I have a friend with a steady soldering hand so I'll have him do it.
    Anybody know the pinouts that a nexttel serial cable uses? I bet I could make a serial cable myself. This means... serial NEMA GPS output!
  6. #16
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Here's a question for you...
    It has nothing to do with internet, etc...
    When check voicemail from the actual phone, if you dial your Boost number (not DC number) instead of checking your voicemail the normal way, does it count as a mobile to mobile call and only charge you 10cents/min?
    Peace,
    Rafster
  7. #17
    Jun 2005
    Anoka County, MN
    No idea.
    Lots of pictures update:
    I went to sears and bought a T6 pocket 1 1/2 torque screwdriver and completley dissassembled my i415. The objective here is to take apart the phone so 1. I can access the power button and turn on the phone via an external power button (or trigger [car starting], or timer (restart phone every 15 min in case mologogo hangs or someone calls and interupts the prog)
    Note that if you do this, you probably void your warenty and are responsible for any breaking of your tech
    Phone dissassembled, first pic. Simply removed all 6 torque screws and cut the 2 wires going to the speaker phone:
    http://img223.imageshack.us/img223/3693/10025232eh.jpg
    What the keypad really looks like:
    http://img223.imageshack.us/img223/2403/10025200cd.jpg
    Backside of phone:
    http://img223.imageshack.us/img223/631/10025245dt.jpg
    Disconnected the LCD from the faceplate of the phone. It just prys right out.
    http://img223.imageshack.us/img223/5989/10025256yx.jpg
    Everything is still working:
    http://img223.imageshack.us/img223/5495/10025262us.jpg
    Pop the LCD off of its plastic mount. It looks like a plastic film is glued onto the bottom of the frame and the LCD itself with a weak adhesive, just work it free. On closer analysis, I think the film is reflective on the backside (reflecting the backlight onto the LCD)
    http://img158.imageshack.us/img158/3334/10025284gq.jpg
    It appears the white keypad layer is just a bunch of concave foil buttons, when you push them in they are concave in and bridge the gap for the circuit on the buttons. This peals right off.
    http://img158.imageshack.us/img158/8797/10025319de.jpg
    Can still start the phone with a screwdriver bridging the contacts.
    http://img158.imageshack.us/img158/5684/10025324eb.jpg
    It's crying because I aren't holding the simcard onto the surface, just the battery. However, this shows you could just solder the points for the battery and the sim onto the respective points on the phones board.
    http://img158.imageshack.us/img158/3944/10025357lz.jpg
    Another shot of progress so far. In this shot, I cut away the rest of the plastic lcd frame that wasn't connected to anything and was wasting space. Don't sisor the glued on circuit board!
    http://img158.imageshack.us/img158/4745/10025365oq.jpg
    Alright, that is all I am doing to the phone for now. Now for the construction of the data cable / car charger: I found a nextel charger for $1 at the local dollar store so I figure I could but another one for trial and error (one from ebay is still arriving in the mail). Stripping its end like I did for the data cable reveals:
    http://img275.imageshack.us/img275/2265/10025373ju.jpg
    The points on pins 3 and 16 are large enough that even my uncordinated self could solder them to the data cable points. Result:
    Throw on some black electrical tape:
    http://img123.imageshack.us/img123/3337/10025396ej.jpg
    Progress so far (with completed data cable in shot):
    Ok now I have a few things left:
    1. Figure out where and how to put LCD in the dashboard of the car
    2. Have my better than me at sodering friend to make a external on/off button for the cell
    3. Determine what components from the back of the phone I need.
    Look at this:
    http://img123.imageshack.us/img123/5626/10025410em.jpg
    Obviousally the bottom 2 connectors are for the sim card and the battery. It is the rest I am interested in. I think the tiny wire in the upper right is for antena, and I am unsure of the other 2. The vibrate component is in the middle, but its 2 contacts dont appear to touch the corosponding contacts on the phone's circuit board. Perhaps that is what the contacts in the upper left do? Or perhaps that is for gps (but doesnt gps need 3 connections, one for RX, power, and ground)? Is the GPS on the circuit board?
    Thoughts?
  8. #18
    Jun 2005
    Anoka County, MN
    This article gives insight on how to make a usb cable that reads nema output for nextel phones:
    http://www.blogcadre.com/blog/roboge...2#comment-2971
    I think one of the keys is by bridging the connectors 13 and 17 pins, it enables serial mode and the TX line can output NEMA data, but then the usb cord doesn't work. So you can't have a location tracking, internet serving, gps navigating device all at once.
  9. #19
    Apr 2006
    Chicago, IL
    Thanks for the pics - I'll be soldering together my charger and data cable this week.
  10. #20
    Jun 2005
    Anoka County, MN
    Rafster, any updates?
