Page 29 of 48 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 475
Thread: Boost mobile?
  1. #281
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've got the i450 and purchased a data cable from an Amazon retailer. Turns out it was the wrong cable.
    Anyone have a link to the proper charger/USB cable? The phone works fine, the GPS is close enough for gov't work and I'd like to be able to use mologogo to implement car tracking for cheap.
    Thanks in advance!
    Want to:
  2. #282
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  3. #283
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Beautiful! Thanks for the link.
    Want to:
  4. #284
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've posted how to use the Boost Mobile phone on a Macintosh for us Mac users. The thread is located here
    Want to:
  5. #285
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Here what I found about the Cable & driver
    Cable Web Site
    price is $15.99
    Companion Pro Software - USB
    Serial Driver
  6. #286
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This thing is cool. I'm running the Motorola i455 and did a speed test on it. Results attached. The blue area on the graph is my upload speed for my cable service (road runner), the gray is the download speed for it. The yellow/green stuff all the way on the left is the i455 modem.
    I'm on an 800 mile round trip this week and I'll try it out in the car to see how well it works on the road.
    Want to:
  7. #287
    BAF
    BAF is offline
    May 2005
    I got my new i836, which to my surprise DOESN'T have widen. I get about 30 kbit up and down. Also, modifying a non-charger data cable to charge was dead easy. USB ports provide 5v at 800ma, and my phone calls for 5v at 500ma for charge. So I just soldered small jumper wires from the data power pins to the charger power pins, and now my phone gets powered/charged by my computer.
    Also, I saw a bunch of people asking for widen enable. I can do this, so if anyone here wants/needs it enabled, just post your codeplug (Google for more info on how to get your codeplug) and I can enable it for you. I can also enable other mods if you found some that you want.
  8. #288
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Boost Mobile in Action
    Last week I took a trip from New York down to North Carolina and used the Boost Motorola i455 and mologogo for mobile net and vehicle tracking. I'm reporting on my results here. (BTW, if anyone wants to set up quickly, go to mologogo's store and buy the whole kit for as little at $59.99 USD. They also sell the data cable for under $10.
    The Good
    It costs a mere 35 cents US a day, or about $10 a month for the data plan. There are no limitations to the amount of data.
    It works. It really actually works. The tracking software is dead simple to use once you've loaded it on your phone. You launch the mologogo java app and forget about it. I've attached a screenshot from my tracking page that shows the trip as recorded by the mologogo service. You can see that there are periods when either there were no reports due to spotty coverage or the app wasn't running but as far as figuring out where I was, it works. To see this page live, go here.
    The cell modem also works. I logged on and checked email, weather, and traffic as we moved along. The connection only dropped a single time and was by and large rock steady from a modem standpoint.
    I used Goops to implement Google Earth tracking on a Dell Latitude Piece-O-Crap(tm) 600 from work. It worked well for the most part. However, the laptop would periodically freeze up and require a reboot. I'm almost certain that this is a Google Earth problem, or more specifically, a Dell hardware issue when using GE than a Goops or modem issue.
    In general, GE was able to download the road and map data quickly enough to make it a usable nav solution. There were a few times when I would drive off of the road and out onto a blurry background but since I'd also used GE to plot out directions, I had a purple line showing me where I ought to be and in just a few minutes the cell modem would catch up to where I was and restore the proper labels and terrain data and so forth. I'd use it again as a primary nav product.
    The Bad
    There's a reason that there are no limitations to the amount of data. The modem is slow. As in sloooooowwwwwwwwww. When coverage is good, I was able to load pages at www.wunderground.com in reasonably good time -perhaps 1-2 minutes. When it was poor, it could take 10 minutes to get a page or worse, Firefox would time out because it got no response from the server. In all cases, simply driving a bit farther and trying again would fix it.
    There were no cases where I simply wasn't able to make a connection after some time. However, it should be obvious that audio and video are out of the question. RSS feeds might make the whole setup snappier.
    The Ugly
    There's no ugly from my standpoint. Well, I guess that I haven't been able to iDen enable the phone yet, so all of my comments are based on use of the cell modem at a very low speed. I thought I'd enabled iDen but since there isn't any iDen service where I live I can't really tell if it is enabled or not.
    Also, if you receive a call, mologogo suspends and you have to reactivate the program. This includes when you get a voice mail notification. Occasionally, the application will hang and stop updating your position. It isn't always clear about when this happens but it seems to occur when it has trouble downloading data for the onscreen map for awhile. Restarting the app fixes the problem.
    The Verdict
    For a cheapskate like me, the $10 a month price tag outweighs slow net access. I love having both net and tracking in the car, but then again, a lot of people don't want others to know where either they or their car is. Obviously if someone can look up your car location, they can find it and steal stuff out of your car. Since my system is dockable and I remove it from the car when I'm not in it, I don't worry too much about it.
    The Boost solution works for both me and my car because I rarely talk on the phone and I don't text people on it. It's strictly an emergency phone or a way for my wife to find out "Where you at?!". Thus, it provides an ultra cheap phone service plus a modest data capability, which is exactly what I wanted.
    Want to:
  9. #289
    May 2006
    Seattleish, WA
    Quote Originally Posted by Bugbyte View Post
    Dude... THANK YOU - in the 15 pages of babble here, this is simply the clearest example of what to expect from this setup.
    Sad to say, it's probably going to keep me from going this route, but now I have solid information about the experience.
    Thanks again.
    :: Mark
  10. #290
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    In regards to slow speed - some people may wonder what you can do with slow speed. The answer I think is cached content - if you wrote a script to constantly download your traffic web page or weather web page and store it locally, you could view the content on demand at any time without waiting for it to download. Boost also works well for very low bandwidth situations such as position updating, emailing, instant messaging, shell scripting (with ssh), and browsing without images.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
