Page 45 of 48 FirstFirst ... 3536373839404142434445464748 LastLast
Results 441 to 450 of 475
Thread: Boost mobile?
  1. #441
    Sep 2007
    when you sign up just tell them you want the data plan
  2. #442
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Did anyone determine whether data feature actually needs to be purchased?
    Is WiDEN still activated on Sprint Nextel networks?
    Wikipedia says:
    Quote Originally Posted by Wikipedia
    WiDEN has not been active on the NEXTEL National Network since October of 2005 when rebanding efforts in the 800MHz band began in a Sprint effort to utilize those data channels as a way to handle more cellular phone call traffic on the NEXTEL iDEN network. To this date, WiDEN has not been restored.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
  3. #443
    Jan 2006
    Every so often, my stupid i455, connected to my PC via USB for DUN, stops being recognized by Windows and it drops off the list of installed modems. Anyone else have this problemo?
    SG
  4. #444
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    when im using DUN it kills mologogo at some random time which is the problem im having. using a i415.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  5. #445
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    I don't know if this has already been posted, but here it goes.
    I never signed up for the 35 cent a day data plan, but my phone works as a modem (data cable to computer) and other java apps (mologogo and opera mini) work.
    I just put $20 (cause I can never find the $10 re-boost cards) on the phone every three months, (balance rolls forward, have ~$60 now).
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  6. #446
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    so are you saying it's free? you don't have to re-boost every 3 months right, as long as you still have the original 20 in your account? I may try this, how's the speed for checking email and weather?
  7. #447
    Feb 2001
    Quote Originally Posted by BREWDOG52 View Post
    You have to re-boost every 90 days. When you re-boost your balance is extended for another 90 days.
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
  8. #448
    Jan 2006
    HELP! I've been using Mologogo on an i455 for months now and it works beautifully...but after a few days, the phone stops communicating with the Mologogo website - this is apparently because the java software on the phone crashes after a while. I'm thinking the java implementation on the phone isn't designed to stably run java programs 24/7 for long periods of time.
    SOLUTION: All we need to do is turn the phone off/on every day or so! Manually turning off/on the phone seems to make everything work again! So, does anyone know of a circuit that does the following:
    1. closes relay for 1 sec.
    2. waits 10-20 secs
    3. closes relay for 1 sec.
    THEN, repeats #1-3 every few hours or so?
    Thanks!
    SG
  9. #449
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think there's a way to make the app restart every day. It's buried in this thread somewhere.
    Want to:
  10. #450
    Jan 2006
    Quote Originally Posted by Bugbyte View Post
    There is, but it requires the application to close itself after a set period of time. If the application "hangs," it can't close itself down and restart. I already have the app set to restart 4 times a day, and it still hangs sometimes.
    SG
