Make sure and update the firmware on the Router and the drivers on the card. If that doesn't work, check the settings on your router.
You could even un-plug the power on the router and leave it out for about 30 seconds then plug it back in to reset it to default settings.
If none of that works then email Linksys and ask them if this is a common problem. If it isn't ask them how to fix it.
LinkBack URL
About LinkBacks
