Results 1 to 10 of 19
Thread: Using Sprint Samsung A920 As Modem
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    How do you do this? I managed to dig up my data cable that I thought I lost, but I lost the driver CD. Found the drivers for an A900/940, which is pretty much the same as an 920, installed them on my shuttle. It found my phone as a modem, I setup a dial-up connection. Is this the right direction? I didn't get to take it any further as I am at work and had to clock back in, and don't have a spare monitor.
    But after I get this far, do I have to still use it as a "Dial-Up" connection and log in as 777? I had did a quick search about "Sprint" in this forum, and it pulled up a thread from '04, which was last posted to early this year, just wanted to know if this is still the way to connect.
    Elsewhere
    I don't know.
    You might try http://www.howardforums.com though...
    How about the Wiki?
    Sep 2005
    You can download the sprint connection manager from www.sprint.com/downloads they have a version with all the drivers for samsung handhelds. I'm not sure about actual usage cost though. I know in the AZ area they have unlimited "tethered" data plans for $40.
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by u4ia
    As far as I know, if you get the Sprint Power VisionSM Access Pack for $15.00/month you can get unlimited tethered access to the internet...
    Peace,
    Rafster
    Nov 2004
    St Louis
    Quote Originally Posted by Rafster
    Peace,
    Rafster
    As far as I know the above is only for non-EVDO phones, which I thought the A-920 is. Unlimited EVDO as a data modem is $60/mth here.
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by Twinsen
    Yes that works, and here are the complete steps. I have the A900 and as far as I know the steps are the same. DO NOT INSTALL the Sprint PCS connection manager... just see the steps here -HERE-
    Basically you have to disable the phone's modem NAI and then it'll let you connect via the #777. There is debate as to whether or not you'll get charged for this, some have, others haven't. I have the Power Vision Pack with unlimited data/web, so we'll see... I've been using mine for just under a month now... :-) I have been connecting at about 930kbps :-)
    Also I have the A900 drivers that I use on my site in the CarPC Software Section. You can use either the USB data cable or Bluetooth to connect. I use Bluetooth, but have connected with the USB data cable.
    Apr 2006
    Memphis, TN
    Sweet, exactly what I needed, I'll give it a try on my break.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    since this thread is about sprint, i have treo 650, so all i have to get is the bluebooth doogle or whatever to connect to internet??
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    Quote Originally Posted by kickercivic1
    naw... youll also need pdanet (http://www.junefabrics.com/palmnet/)
    then you just get the bluetooth dongle and install palm desktop and only then will be ready to go on the internet with your PC/laptop!
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    Apr 2006
    Memphis, TN
    Well, thanks for all the help, works fine on my phone. Don't know if it'll be charged or not. I am on the Unlimited Vision pack, so I dunno. But man, its barely faster than dial up. It connects at I think 280kpbs, and downloads are 32kbp/s...
