Are you talking about the WG111? If so, I just bought two and they're pretty dern nice.
What you're asking about is what's known as "AdHoc mode" which is where you setup what's called a "point to point" network between two machines.
Yes, you can do it, yes, it will work. _BUT_ there are a couple of things to make it complex:
- If your home computer is on the 'Net, then things will get interesting to setup for the carPC.
- Don't expect the carPC to be able to get onto the 'Net just 'cause your home machine is. That can be worked out, but it'll take some networking knowledge. The home machine will need to be setup as a "gateway".
- Also, the network configuration on the home machine will be "interesting". That machine will need to become the center point of two subnets. XP _PRO_ will let you configure this, I don't know if XP Home will.
- Running two network paths on a single machine isn't the best thing in terms of speed. Depending on the CPU & RAM in the home PC, it could get bogged down.
- I figure that you're talking about Windows XP on both sides, right? XP, like all other Windows OSs has a real issue with USB network interfaces. They work right up until the point that you bring the machine out of Sleep or Hibernate. 8/10 times you'll have to unplug and replug the interface (or warm start the machine) to get it to work again.
- An AdHoc network is pretty open... you can secure it in the normal ways, but be careful with leaving the thumb installed on the home PC.
- In the end, you may be better off getting one USB thumb and a nice wireless router. It'll secure your home PC and let you _truely_ network the carPC which means it can have Internet access while it's in the driveway.
WarDriving wise... I dunno if that's okay to talk about here.
LinkBack URL
About LinkBacks
. Still say access point is the way to go tho for loads of reasons.
