There is no reason why a PCI-to-PCMCIA adapter with a Verizon EVDO card wouldn't work.
I believe there are people who have done the same thing, although using the integrated PCMCIA in the MIII10000 motherboards.
If you're using a touchscreen that's designed for PC use (like the ones in the mp3car.com store), your idea about the laptop would work just fine.
If you're talking about a touchscreen integrated into an all-in-one headunit, then that's not going to work, as that touchscreen will only control the headunit.
Someone did hack a Kenwood headunit and get the touchscreen working on a PC. However, I wouldn't want to crack open a $1500 headunit jsut to pull this off...
Someo
LinkBack URL
About LinkBacks
. I've spent the last couple days searching the forums but couldn't really find a distinct answer. I was thinking bout getting a PCI to PCMIA adapter and using EV-DO service from Verizon. But from what I understand, no one has been successful in using this in their CarPC right? I want a fast internet connection so I can hook up a SlingBox to watch cable tv in the car. What's the best current option available? And if comes down to it, can I just hook up a
