Results 1 to 10 of 19
Thread: wireless router inside car?
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    i was wondering if anyone has installed a wireless router (access point? im not really sure of the difference) inside their car.
    im planning on getting verizon broadband for my carputer in the near future, and since everyone and their mother has a wifi-enabled laptop these days, i would like to make this internet available to my passengers as well.
    are there any threads about attempting something like this?
    carputer - done.
    Mar 2006
    San Diego, CA
    I'm sure someone has done this before. Here is the issue, the Verizon card is only going to provide access to the computer it is connected to. Instead of a router, you will need that PC to use Internet Connection Sharing. Then your passengers will connect to your PC via wireless ad-hoc. Should work...
    EDIT: The difference between a router and access point is a router will issue IP addresses to clients connected to it and an Access Point will provide a wireless connection to a network, but has no IP addressing capabilities. Hope that helps.
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    There are wifi routers with a pcmcia card slot that allows just this. They cost $300 or so though. Look up stompbox, Junxion Box, Kyocera KR1.
    Failure is not an option....
    It's installed by default on every version of Windows.
    May 2005
    Quote Originally Posted by BarryWoods
    well i dont have a pcmcia slot, and i do have an ethernet port that im (obviously) not using....
    edit: you mean that the router would get internet access through the pcmcia slot, and my computer would access it through ethernet?
    carputer - done.
    Oct 2004
    NY
    I have the kyocera kr1.... it's sweet
    May 2005
    Quote Originally Posted by turbocad6
    what card are you using it with?
    carputer - done.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Expensive/easy solution is to use one of the those new routers meant to share a cellular pc card internet.
    Or use window's internet connection sharing or a software solution like Nat32 and then using a router or access point connected to the carputer's network card as it's internet source. Windows networking is a pain so it'll probably take some tweaking and playing around with to get it to work reliably.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Aug 1999
    Washington D.C.
    I have the KR1, it's works really well.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I stole Zip-Lock's first KR1, I agree it does work really well
    http://www.mp3car.com/store/product_...roducts_id=240
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Oct 2004
    NY
    I use verizons evdo service... I have the pc5220 ..... it was the first evdo card that came out from verizon, before that I had an aircard 555 verizon with there 1xrtt express network, even that was so much better than not having anything....
    I love it & would never want to not have it.... internet.... anytime, anywhere... I'm glad it came down from the $79.99 it used to be, but it was worth every penny, even back then I think.... I also have a treo 700w with evdo, I always figured I could use this if I'm ever away from the car, but for some strange reason the pc card just works so much better than the 700w & is a better connection.... I've used it both ways, through the cell & through the pc card.... if you use internet allot it's nice to have the seperate card.. I find myself using both at the same time plenty of times
    the kr1 just makes it that much better, I used to have to remove the card from the carpc to connect my laptop, even if I had the laptop in the car..... now, the kr1 connects & make my car a mobile hotspot whenever running, while freeing up my pc slot in the carputer.... I sometimes visit my sister, & while the kids are playing & the women are yapping, I just remote start the car, & then browse the net with my laptop in my sisters house(she has no internet ), while the car is outside running & providing a hotspot...
    it's usually pretty quick connection wise... it does seem to be a bit slower sometimes at like peak times, but for the most part really great...
    I have had one issue with the card though, sometimes infrequently it will dial & connect, show a connection, but not have any data throughput... I used to just disconnect & reconnect, but now that it's parked in the router I have to reboot the router to restablish a new connection... I don't know if this is a service issue or a hardware issue... sometimes it is a little annoying but it doesn't happen to often...
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Wireless Router in car - Has any done it?
    By mmendis in forum General Hardware Discussion
    Last Post: 02-20-2007, 11:34 PM
  3. Attention Newbies! A FAQ to the FAQs
    Last Post: 06-16-2006, 12:17 AM
  4. $10 after rebate travel sized wireless router at Compusa TOMORROW!!!
    By Genesisfactor in forum Classified Archive
    Last Post: 04-01-2006, 10:40 AM
  5. WTB: Wireless Router and PCI adapter combo...
    By jbeckford1 in forum Classified Archive
    Last Post: 03-31-2006, 04:37 PM
