so.....you wanna use a phone.....with no subscription?
you wanna pay $1 a minute?
Does someone know if there is a hack to connect the integrated phone to bluetooth or something of that nature. Or in plain to use the integrated phone system with MY cellphone (not verizon) and without subscribtion?
2005 tahoe
PC Components:
My work log
No. There's no way to utilize the onstar speaker/mic with your standard phone, not over bluetooth, not over anything. You can't use it without a subscription, and you can't tie it into anything except Verizon.
Once again, this is a Car PC forum. You might have better luck checking out either a Tahoe forum or something like Howard Forums. Not that you'll get a better answer than 'NO', but just giving a heads up.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
I have to to do #1 now. My existence isn't complete without that.Originally Posted by DJiK
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
first of all, thank you to the people that tried answering my thread. 2nd, why is it that people who have no freakin clue even respond.
Let me make it clear what i am wanting to do.
It is possible, as many of you know......to use the onstar gps feature with your own pc/ laptop/ carputer. etc. with a fairly simple hack/ mod.
I want to use the MIC/ SPEAKER for my own phone, by attaching/ soldering a bluetooth adapter to the onstar's phone unit. I simply would like to use the equipment in the car that happened to be linked to onstar.
With the hacks I showed you above, you could do just that.Originally Posted by TangTang
All you need is a $30 BT HS, OnStar's schematics, soldering skills, and time.
Good luck.
Relax man, that's what forums are all about, learning from others. It's good that jahntassa participated in this form, cause he now knows it can be done...Originally Posted by TangTang
I think Jahntassa was going along the lines of not hacking, about keeping it the same stock stuff... You can connect just about anything to anything else by choppin it up and attaching something else to it.
It's ok. That's why we're here. You have no clue either, why else would you be asking?![]()
Take it wasy newbie.Originally Posted by TangTang
Who cares quite being cheap.Originally Posted by TangTang
Your repeating yourself.Originally Posted by TangTang
