Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: PCMCIA > USB adapter for wireless cards
    _
    Mar 2004
    Little Elm, Texas
    Please note, I am NOT referring to your typical 802.11G/B PCMCIA access card, I am referring to the 3G broad band access cards from cell carriers.
    I'm trying to search for options other than the one in the store: here
    But I'm not having much luck.
    here's why I need a USB adapter:
    • Where my computer is located, I have a limited amount of hight to work with and most PCI cards are too tall for the location
    • I'm not using a case, so I have nothing to secure a PCI card to
    • I WILL not be using a case as I don't have anywhere to put one
    • I have to be able to easily access this card so that I can remove it very quickly when entering and exiting the car. I use this card with my laptop as well
    • Networking with my laptop to share the wireless connection while in the car is not an option. I am not interested in hauling around my laptop every time I get in the car to go somewhere.
    Does anyone know of any other options other than this one dongle?
    Jan Bennett
    Jun 2006
    You could just get a USB network card with external antenna and your problems are solved. This way you do not need to remove the pcmcia adapter from your laptop at all.
    Low Bitrate GRod's Avatar
    Aug 2003
    San Diego
    I've searched and searched for the same thing, and the only other device that I've come across is this one
    http://www.evdoinfo.com/Events/CTIA_...m_20060407720/
    Carputer/AV System ~95% complete
    Parts all acquired - testing underway
    Fabrication and integration underway
    More on my Ride
    FLAC ppgt94's Avatar
    May 2001
    USA
    My old Lucent USB Wifi AP actually had a USB PCMCIA adapter inside the plastic case with a Orinoco silver plugged into it. I replaced the silver PCMCIA inside with the gold version and added an external antenna. Worked great for a while until I bent the pins and broke a few. I searched for another like adapter but eventually gave up and decided just to mod my antenna plug to fit my Netgear PCI 802.11g card and use that. If you can't find a seperate dongle your best bet might be on one of those Lucent/Orinoco/Proxim USB APs on ebay. You can replace the PCMCIA card with one of your liking, like I did. I made a post about it back in '04 where there's a little more info
    Here's what they look like inside:
    source - more info
    Let me know if you ever find some off-the-shelf adapter for this.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by jeremy480
    I'm speaking of a Broad Band Access card, NOT Wi-Fi
    this is the stuff where I can be just about anywhere and get access.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by GRod
    I had a coworker link me to that earlier as well. Too bad there's nothing more about it though...lol
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by ppgt94
    source - more info
    again, this is NOT for wi-fi - it's for the cell phone access anywhere broad band cards.
    Jan Bennett
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by Red GTi VR6
    I'm pretty sure it will work with any pcmcia card. Though on second thought it might not like cardbus cards.
    Failure is not an option....
    It's installed by default on every version of Windows.
    _
    Mar 2004
    Little Elm, Texas
    From what I'm gathering, and someone point me to a source if I'm wrong, but the broadband card like what I've got requires something different than a typical wi-fi card.
    I really have no idea what could be different, but I'm also not up to speed on the different protocols and data transfer capabilities differences.
    Jan Bennett
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    http://www.roalan.com/USB%20to%20PCMCIA%20Adapter.htm
    the second one. ITs cheaper, but doesnt support all the networks.
  1. Head Unit USB Adapter
    By unr3al in forum General Hardware Discussion
    Last Post: 09-22-2005, 12:02 AM
  2. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 07:15 PM
  3. USB -> Parallel -> HD44780 LCD
    By Zip-Lock in forum General Hardware Discussion
    Last Post: 03-09-2005, 06:31 AM
  4. Pocket PC With USB HDD and PCMCIA Sound Card?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-23-2005, 05:26 PM
  5. u-lcd2 (usb adapter for character LCDs) any good?
    By asteroid in forum LCD/Display
    Last Post: 12-26-2004, 12:18 PM
