Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 77
Thread: WiFi Hopper - WLAN Scanner and autoconnecter
  1. #41
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by kiztope
    Has anyone from Mp3car.com looked into getting a special rate for us?
    According to the website: Discounts are available for those who purchase more than 5 licenses. Maybe a discount could be made available for the mp3car.com store, and we could purchase it through here!
    I was about to download the evaluation, but I would like to know what you guys think... In your opinion, does this program work well enough to buy?
    Thanks!
    I'm pretty happy with it, but my evaluation expired How much is a license?
  2. #42
    Newbie pcsofty's Avatar
    Oct 2003
    Thanks!
    I'd be willing to buy if a discount was available!
  3. #43
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Has anybody used this with their gps? How do you read the nmea files?
    It seems my reciever, and I have iguidance, I wonder if the two can work together.
    2000 Sunfire build 100%, or is it ever really 100%?
  4. #44
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    if you only use iguidance it would be pointless to use it with your gps since iguidance cant be "written" to.
    Live mp3Car Facebook Chat
  5. #45
    Aug 2006
    Actually the two "sendkeys" exe's (wifihop and wifimanage) made by Sonic doesn't works with Autoit1.2... I tried to run them manually but the status doesn't change, am i doing something wrong?
  6. #46
    Woodbridge, VA
    Blog Entries
    55
    autoit1.2? The current autoitversion is 3.2.0. upgrade!
  7. #47
    Aug 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    No, i'm talking about WiFi Hopper! Eheh.. i didn't realized you were using these exe's with AutoIt! ...ok now i know, i'm gonna re-code em to send out keys directly to Wifi Hopper, without need to install AutoIt.
    Tnx.
    EDIT: i'm not sure why we're doing this.. according to the WiFi Hopper doc:
    To enable the Connection Manager mode, select Mode > Connection Manager from the Menu. In the Connection Manager mode, WiFi Hopper will continually scan for wireless networks. It will compare each network to each saved profile taking into account options such as Match BSSID. Once a compatible network is detected, it will continue scanning to ensure Priority is taken into account. Finally, it will initiate a connection to the most suitable network automatically without any user intervention.
    It seems that the CTRL-3 option already do it automatically... maybe it connects to the most suitable network when it is already in the list? Hum........
  8. #48
    Woodbridge, VA
    Blog Entries
    55
    yes it works that way, and doing it the way you suggest is fine. However what you'll find is when you're in an area with a alot of hotspots wifihop will ignore priority and just skip to the network with the strongest signal... over and over each time this happens you lose connection. So when you HAVE connection, you wanna be in network manager and not network hopping mode
  9. #49
    Aug 2006
    Hi Sonic, tnx... now i'm stuck with the "EXISTS;" command in RR.. i tought it was a embedd RR command, but it isn't? I've read the doc and there's no mention about this command, prolly i'm totally wrong.. but where i'm wrong?
    I've checked the entiere forum and i found vague infos on "file exists indicator".. but the indicator won't work with this forma:
    ....."EXISTS;c:\connected.txt"....
    Any help?
    EDIT: guess what...? Old RR version.. coz i used the installer. My bad.
  10. #50
    Aug 2006
    Autonetdetect and the RR indicator (it's custom on main screen) are causing now interruption on the "music", i'm sure it's not NetHopper coz i tried to disable it and the interruptions remains... there's any way to increase RR priority? And for your experience, this would solve the problem? Thanks.
