Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
Thread: WiFi Hopper - WLAN Scanner and autoconnecter
  1. #51
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    open the task manager.. right click rr.exe.. set the priority to high.
    Live mp3Car Facebook Chat
  2. #52
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Quote Originally Posted by Puffanug View Post
    It looks like this app also can tell you GPS coords of where the network is. I tried a similar plugin for NetStumbler and Google Earth, it was pretty cool. Had little icons popping into Google Earth of where wifi spots were.
    Can I get a link for this? I use GE with GooPs anyway, so a Wi-Fi location overlay would be awesome.
  3. #53
    Aug 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Thanks Sonic, i'm doing a more precise research, and the problem here seems to be the filecheck control on my skin:
    Code:
    I,65,55,16,22,"EXISTS;C:\connected.txt"
    IMG,65,55,16,22,"online_o.gif",on
    It seems this continuos check causes the audio to be interrupted, BUT it doesn't occours always.. maybe it occours only when a network is detected, i really dunno.
    I'm gonna try the priority option. Hope it solves the issue.
  4. #54
    Woodbridge, VA
    Blog Entries
    55
    i havent had those issues.. but i'm using a pretty powerful pc.. i guess if you're using alot of system resources adding that incidator could lag things a bit
  5. #55
    Newbie PaulieWalnuts's Avatar
    Nov 2005
    Norfolk, VA
    can wifihopper be used on pda's (pocket pc)?
  6. #56
    Sep 2006
    can some one please help me incorporate autonetdetect and these two other small programs into the rr skin BMV2 as the online indicator i did it as the exists comand but it just will not show up any ideas?
  7. #57
    Constant Bitrate avengerki's Avatar
    Mar 2006
    Oregon
    If your not worried about it constantly changing connections do to better signal strength you can set the program to remember the mode automatically so you dont need to use an autoit script to set it to hopping mode. You only need the script if you want it to connect and not switch to a stronger signal.
    Currently at work so I will look to see where that setting is when I get home tonight.
    Avengerki
    PC Install: 85%
    Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
    Software install and setup: 35%
    Entertainment Package: 85%
  8. #58
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by avengerki View Post
    That's what I want to do. How do you set it to start in hopping mode without using the script? Ideally, I'd like the program to load at windows startup and start in hopping mode.
    Also, is anybody else finding that WiFi hopper and hibernation don't play nice together?
  9. #59
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by kbreeden View Post
    Ah, I now see that those settings exist right in the proggy.
    For anyone who cares, the program embeds well in Centrafuse. It doesn't want to reconnect after hibernation, though. If I close out the program before hibernating things go better.
    This is really a slick little program.
  10. #60
    Jul 2006
    British Columbia, Canada
    are you guys still interested in discounts for wifihopper. I know the guy who developed the software, if you are interested i can ask him if he is interested.
