It is already embeded, what i mean with autoconnect is that
WiFi hopper has som "lacks" in the hopping/scan procedure. It seems to work fine only in "scan mode" ...in that mode it scans for the networks and logs correctly, then it autoconnect to any available network marked as "preferred" (you have to register it before...); in the other 2 modes it seems to not works: in hopping mode the scan seems to not work correctly... the only wai to automatize everything is to leave the
Windows Zero Configuration enabled and the hopping in the "scan mode", in this way it scans for a network, but the Windows ZC manage the connection to any available network, but this cause serious troubles to my system: CPU usage coz it is costantly search for a network to connect to.
What i see is: if i want to connect (with ZC disable) is that i've to manually double click on an available wifi connection, *IF* it is not stored in the preferred ones (eg: it autoconnects to my homelan.. but in the city i must select a connection manually from the list).
