Results 1 to 5 of 5
Thread: How To use your Blackberry as a wireless modem
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Hello All,
    The following will describe how I got my blackberry to connect to the internet as a modem, and how I integrated it into my front end. I use RoadRunner, but the procedure should be relatively the same between the various front ends, especially since it is mostly accomplished with some Autoit Scripts that I created. Of course, you will need to edit the scripts some to get them to work for your situation, but at least this will get you started.
    Before I begin, I just want to let everyone know that there most likely is a better, more efficient, more elegant, easier, etc... way to accomplish this. This is just the way I did it. If you have suggestions, that would be great, I might change mine to make it better. But, if you ask me why I did so and so, the answer will most likely be, just because that is how I did it, and it works.
    What you will need:
    You will need your BB software
    A USB cable for the BB
    A compatible BB
    AutoIt version 3 Installed on your carputer.
    Now, in order accomplish using your Blackberry as a Modem, you have to first make sure you have a BB that can be a modem, and then you have to install your desktop software on your carputer, and setup a dial up connection in your OS. Also, UNFORTUNATELY, you have to actually connect your BB to the carputer using a USB cable. BB/RIM does not allow a DUN to be established over BT (sucks really, but what can I do). I would suggest you follow the instructions at www.blackberryforums.com. If you have a BB, and have never been to Blackberryforums.com, then you are missing out. That is THE blackberry forum. Here is the link in particular to setup the DUN. Follow it to the letter. http://www.blackberryforums.com/blac...ighlight=modem
    Make sure you test the connection before you begin (I know, common sense, but I should mention it)
    When you are done, you will have a connection icon where you created it from the instructions on BBForums. Make sure it is a shortcut (has an .lnk extension). If it is not a shortcut (it should be, but just in case it is not) right click on the icon, and click create shortcut. Then rename it to something like "BB" (it should automatically add the .lnk extension) Then cut and paste the shortcut into your root drive, that means onto the C: drive. Ya, it might work in other places, but I found that I had problems running it from the desktop with AutoIt. Remember, it might work in other places, I put it in the root.
    Then find the icon for Internet Explorer. Again, create a shortcut, this time to IE, and move the shortcut to the root directory. I would also name it "ie".
    Now, do the following
    Open IE, with the link or anyway you want
    Open the Blackberry Desktop Manager
    Open up a command promt (go to start>run>type "cmd">enter
    With the "autoit Windows info tool", confirm the name of your blackberry
    desktop manager window. Mine was called just that, and yours
    probably is also, and write it down. IT MUST MATCH EXACTLY THE NAME OF THE WINDOW
    Do the same thing for the Internet Explorer Window that you did for the Blackberry Manager Window and do it again for the Command prompt window
    You will need this information for the script(s)
    At this time, I would also determine the exact path for the two .lnk's you created, BB and IE. You can do that by right clicking on the link that you find using the windows explorer (or however you navigate windows). You will also need the path to the Blackberry Desktop software you installed, it should be called "DesktopMgr.exe" and if installed to the default, it should match what I have in the script.
    You will then need to enter the appropriate information into the script(s). Yes, I have 2 scripts, you might only need one, but I used two, and I will explain later on why.
    You should read the Autoit help to figure out how to create a script.
    Script 1
    ; AutoIt Version: 3.1.0
    ; Author: A.N.Other <myemail@nowhere.com>
    ; Script Function:
    ; Template AutoIt script.
    ; Script Start - Add your code below here
    ; Script Function:
    opt("wintitlematchmode",2)
    ;With the "autoit Windows info tool", confirm the name of your blackberry
    ;desktop manager window. Mine was called just that, and yours
    ;probably is also. If it is not, then enter the name below, where I
    ;entered the name. IT MUST MATCH EXACTLY THE NAME OF THE WINDOW
    $BB=winexists("BlackBerry Desktop Manager")
    ;Do the samething for the Internet Explorer Window that you did for
    ;the Blackberry Manager Window.
    $ie=winexists("Microsoft Internet Explorer")
    opt("wintitlematchmode",3)
    ;And again for the Command prompt window
    $CMD=winexists("C:\WINDOWS\system32\cmd.exe")
    Select
    case $bb=0
    ;This is where the path for the Blackberry Desktop manager goes. Make sure
    ; all references are the same
    run("C:\Program Files\Research In Motion\BlackBerry\DesktopMgr.exe")
    winwait("Connected - BlackBerry Desktop Manager")
    sleep(1000)
    case $bb=1
    sleep(1000)
    endselect
    select
    case $cmd=1
    ; This the window name of the cmd window you determined with the
    ; autoit window info tool. Make sure all references are the same.
    winactivate("C:\WINDOWS\system32\cmd.exe")
    sleep(1000)
    send("exit")
    send("{enter}")
    sleep(1000)
    run("cmd.exe")
    sleep(1000)
    send("cd\")
    send("{enter}")
    ; this is the name of the DUN connection link. Notice there is no path. None
    ; is needed because the commands above force the CMD window to the root
    ;drive. Make sure all references are the same.
    send("BB.lnk")
    send("{enter}")
    case $cmd=0
    run("cmd.exe")
    sleep(1000)
    send("cd\")
    send("{enter}")
    send("BB.lnk")
    send("{enter}")
    endselect
    winactivate("Connecting Blackberry Connection...")
    winwaitclose("Connecting Blackberry Connection...")
    sleep(5000)
    sleep(5000)
    ; this is the name of the IE link. Notice there is no path. None
    ; drive. Make sure all references are the same.
    send("IE.lnk")
    send("{enter}")
    sleep(5000)
    send("exit")
    send("{enter}")
    Notice the "sleep" commands might be able to be shortened on your
    machine (5000) is equal to 5 seconds. That is just some trial and error, but like I said, it works for me.
    I also optimized the DUN connection as follows
    Go to Start > Connect To > Show All Connections. Then, right click on your blackberry dial up connection (whatever YOU called it) and click Properties. Click the Options tab, and uncheck "prompt for username and password" and also "Prompt for Phone Number" but leave "Display progress while connecting" checked, the script needs it to determine when the connection is established.
    I also optimized the BB software, so that it doesn't syncronize, which makes the process faster since the connection doesn't have to wait for the sync to end. To do this, open the BB desktop manager, You will see in the middle window the word "Intellisync" just below to opposite facing arrows. Double click that icon. Almost at the bottom, you will see "select the actions to occur when your device is connected...." Click the button to the right of that, and uncheck all the options.
    If you have done the above, and entered all the information (Remember, the paths must match exatcly with your computer, so confirm that everything is spelled correctly), you can test it out. You can do that by just double clicking the .AU3 file, no need to compile the script to an exe yet. In order to test this, you MUST connect your BB to the carputer, or else it will wait till it is connected. The script should automatically start the BB software, then start the dial up connection, and then start IE. Make sure you do not hae any other connections to the internet when you try with the BB, because IE will choose any active connection, and not just the BB connection. If all is correct, IE should start and be at your home page. If it works, then you can compile the script into an exe.
    If you are using an FE other then RR, then you need to figure out how to execute the script from with in your FE. If you ARE a RR user, then read on.
    For RR users, you now need to make the following changes to your RR setup.
    If your skin has a button to access the web, then all you have to do start RR Config, and then in the web browser section, choose IE and then choose the path to your AutoIT .exe file from above. You are then all set.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Continuation
    HOWEVER, I ran into the following problem. I use standby/s3 for shutdown and startup of my computer. The problem is that when the computer enters standby (and probably hibernation also, I just never checked hibernation), it closes the DUN connection. The problem is, nothing else closes, and mthe script is unable to check for a DUN because of the way Windows works. So, when I got back to RR on a startup after standby, after using the BB to connect to the net before standby, when I clicked on the "web" button to go to the net, RR brought up IE as it should, but there was no connection to the net because RR would not "re-run" the script to establish the connection, becuase to RR, the path had been executed, and since IE was open, RR thinks that the path/program is still running. So, I came up with the following solution.
    I created a second script that I would run after a standby event that would establish the connection again, and would refresh IE so that all would be well. This, however, took some doing, and like I said, there might be a better way to do this, but this is what I did.
    Luckily, RR has the ability to assign two functions to a button, one when just momentarily pressed, and another when held for more than 2 seconds. To do this, I navigated to the Menu.skin for the skin I use in RR, and found the button that starts the web. It should be labeled something like this
    B15,652,415,135,110,"WEB"
    Though, it might have something along the lines of
    B15,652,415,135,110,"WEB",@function2@
    Will will bother ourselves with the "@function2@" part. That is the part that determines what happens when the button is held for at least 2 seconds. I entered "INET" into the command line, but you can call it whatever you want, so that mine looked like the following
    B15,652,415,135,110,"WEB",@INET@
    Then save the menu.skin of course.
    Then Navigate to your RR folder, and find execTBL.ini, and open it. Scroll to the bottom, and add the following
    "INET","RUN;C:\Documents and Settings\Administrator\Desktop\rr-inet2.exe||load;wbrowser.skin"
    Then, you should create a second script (I called mine rr-inet2.exe just in case you couldn't tell) with the following
    Script 2
    ; Script Function:
    Select
    case $bb=0
    sleep(1000)
    case $bb=1
    sleep(1000)
    endselect
    select
    case $cmd=1
    sleep(1000)
    send("exit")
    send("{enter}")
    sleep(1000)
    run("cmd.exe")
    sleep(1000)
    send("cd\")
    send("{enter}")
    send("Blackberry.lnk")
    send("{enter}")
    case $cmd=0
    run("cmd.exe")
    sleep(1000)
    send("cd\")
    send("{enter}")
    send("{enter}")
    endselect
    sleep(10000)
    winactivate("Microsoft Internet Explorer")
    sleep(1000)
    send("^r")
    sleep(5000)
    sleep(500)
    send("exit")
    sleep(500)
    send("{enter}")
    You should already know how to create the script, and now that the patchs and window names must match, just like for the first script.
    Again, make sure all the paths and window titles are correct for your situation. You can test the second script by again, making sure there is no internet connection active. Then, open IE, you should get a 404 error or something like that. Then, make sure your BB is connected to your computer, and run the script. If it is successful, you should eventually see your home page displayed.
    Then, just fire up RR, and check to see that is works.
    Remember, if you are not using Standby or perhaps Hibernation, you can skip the second part completely.
    Hope this helps people out. I will answer questions if I am able, but before you ask me anything, please make sure that all the paths and names and locations match what is in the script, because if not, IT WILL NOT WORK. Also, if you ask, please provide as much information as possible, what happens, what is displayed, and a copy of your scripts. In order to do that, DO NOT DELETE THE AU3 file after you compile it, becuase I know of no way to "uncompile it".
    Good luck,
    Michael
    Jun 2006
    Instead of just using your BB as tethered mode - as a modem, did you have any luck using it with RRphone or Phoco ? I had zero luck but seems like you know the guts damn well and that makes you one of my best friends
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by kolemieux View Post
    No such luck.
    The blackberry portion of this came from blackberryforums.com. I know VERY little about the "inside" of the unit.
    The other part was what I learnt from playing with RR and autoit.
    But, I have seen people complain about PhoCo and the other programs, with the BB and various other phones.
    Michael
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    not sure which model you have. My 7290 has bluetooth, but the only service it allows is audio gateway for use with a headset...no data connection capabilities. so tethered it is...for me at least.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. Blackberry 7100
    By Leddy in forum PhoneControl
    Last Post: 11-25-2007, 11:48 AM
  3. Merlin Wireless IP Modem
    By JPuma in forum Wireless Communications
    Last Post: 08-26-2005, 11:07 PM
  4. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 11:46 AM
  5. Wireless internet through regular modem and Cellphone
    By Charliey in forum General Hardware Discussion
    Last Post: 02-17-2003, 09:45 AM
