having the exact same problem.. did you ever figure this out?
I'm using CiDial to autodial my connection. but I need to manual initiate the connection through the bluetooth places after hibernation.
Thanks,
Mike
I have successfully implemented a dial up network using my Verizon LG 8100 phone and blue tooth. The problem is that it works without a hitch when i reboot the system - but it says modem error when i try to connect anytime after i resume from hibernation. I'm betting that it is an issue of the 2 bluetooth devices not syncing but I'm unsure.
Basically:
Initial boot: works
after resume from hibernation: 1 in 10 times will work
after full reboot: works (until i hibernate)
turning the power on and off on the phone does not help
Do i need to stop and restart the BT service on the PC everytime i hibernate? Is there an application that will do this for me?
Thanks,
Mike
