Results 1 to 10 of 14
Thread: Can I FTP into my carpc? Best way to put files in?
    Mar 2006
    NY
    Hope this isn't a re-re-re-repost!
    My carpc will have a usb wireless adapter. The pc is running XP. I'd like to be able to move files from my Mac (where my music and videos are stored) to the carpc while it's in the driveway. I'm running a wireless router in the house that sends a signal outside.
    On my xbox I was able to ftp into the xbox and just move files that way. It was very simple. Is it possible to do the same to the carpc? If not, does anyone know an easy way to move files from my Mac to XP? I don't want to remove the hard drive because I will want to constantly update music and videos, etc.
    Any help would be appreciated. Thanks.
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Quote Originally Posted by ckny View Post
    Depends on what you wanna do. If it's LARGE scale (gigs at a time), then I'd suggest gettin a cheap external HDD for file transfer. If it's a few hundred megs at a shot, then setup an ftp server on yer carputer machine and don't forget to firewall!!!!!!!!!!!!!!
    Mar 2006
    NY
    thanks - i'm not really familiar with ftp stuff but i think i'll take a look at filezilla. i'm sure i can figure it out
    Sep 2006
    Wsftp Server
    heya, try WS FTP SERVER, i used this prog in the days of 56k to tranfer school work to and from home, worked well. Relatively easy to setup. If your moving gigs then yeah like TheLandYacht said....a removable hdd would be the best. Dont forget to disable anonymous login!
    Jan 2006
    Why choose FTP?
    The much easier way to sync files would be to use something like ViceVersa Pro.
    Mar 2006
    NY
    just checked out the website. viceversa looks good the only problem is the main files are on a mac and it appears this program supports windows only
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Syncing your iTunes files?
    Failure is not an option....
    It's installed by default on every version of Windows.
    Oct 2004
    NY
    2 gig thumbdrives are common now, & a spare laptop hardrive in a enclosure is also a great easy way to move stuff back & forth on different platforms too
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    ftp? isnt that overkill?
    Set up windows shares. Have finder connect to the shares with go->connect to server (smb://ipnumber) (example smb://192.168.1.75) and use username guest with no password.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
    Mar 2006
    NY
    that's more along the lines of what i was looking for. purdoom - this may sound stupid but how do i discover the ip address of the car pc to set this up?
  1. Problems with BootSkin and CarPC
    By RedGTiVR6 in forum WinNT Based
    Last Post: 08-02-2006, 10:06 PM
  2. Where to put CarPC and Older Cars???
    By chris|random in forum Newbie
    Last Post: 07-25-2006, 11:21 AM
  3. Replies: 0
    Last Post: 06-28-2006, 03:45 PM
  4. need help planning new carpc
    By burnhamd in forum Newbie
    Last Post: 08-23-2005, 07:32 PM
  5. Where to put the Inverter?
    By MarkW in forum Newbie
    Last Post: 05-28-2005, 02:08 PM
