Results 1 to 9 of 9
Thread: U132 / U111 issue. Anyone else have the same problem?
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Hi All,
    I have a Sierra 860 card and therefore ordered the U111 not U132. Two issues:
    1. After I boot up and try to connect, it dials, logs in to the network and then immediately gets disconnected. This would at first seem to be an issue with the account itself (username/password) but if I take the card out of the U111 and put it into a PCMCIA adapter, it connects flawlessly. I still need to 100% verify the settings are the same here between the two interfaces, but I'm positive username / password are the same.
    2. The adapter is never successful in dialing the card after resuming from hibernate. It gets to "dialing..." and then reports there is a hardware error. Pretty useless for a car.
    Anyone have similar issues?
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    WHERE DID YOU GET THE U111?????? I just bought one of these cards too and I cant figure out how to get it to work either.
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Aug 2006
    Atlanta, GA
    I am going to buy a PCI card tonight with the PCMCIA slot in it. I will let you know how that works out. They are only $50 and support the 16 bit cards.
    Hopfully this will work.
    I have to use the riser card for my mobo to install this.
    2003 E46 BMW
    Jan 2004
    Seattle, WA
    i have one of those and it works flawlessly (got mine for $30 at a local store)...my problem is i'm moving to a mobo w/out pci slot...just mini-pci.
    i bought the u111 from http://www.roalan.com btw.
    Aug 2006
    Atlanta, GA
    what model PCI card do you have??
    2003 E46 BMW
    Jan 2004
    Seattle, WA
    i'd have to go check..was the only one left at the store (Fry's Electronics)
    Jan 2004
    Seattle, WA
    SIIG for the PCI<->PCMCIA adapter, FYI.
    Aug 2006
    Atlanta, GA
    Was the card mounted in your trunk? Would there be any problems using the card in your trunk? It works in a huge building i dont see why not.
    2003 E46 BMW
    Jan 2004
    Seattle, WA
    it was. i did get a booster antenna for the Sierra card though. it works great:
    http://booster-antenna.com/index.php...products_id=89
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  3. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  4. Power-up problem
    By KyleYankan in forum Newbie
    Last Post: 06-16-2005, 04:22 PM
  5. Display problem with laptop lid closed
    By raspyrx7 in forum General Hardware Discussion
    Last Post: 06-04-2005, 12:06 PM
