Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Extending Antenna
  1. #21
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Quote Originally Posted by BarryWoods View Post
    Naa, I was a KC-135R crew chief. I've actually had pretty good luck with one of those blade style antennas. I had it velcrowed to my powerbook display. The ceiling mount antennas have the pigtail coming straight out of the bottom, would be kinda hard to sit on anything without drilling holes. If it was me, I'd just pick up a 6 or 8 dbi rubber duck for the trip and get a mag mount once I got back.
    Crew Chief eh? - NICE!!!
    I've controlled and done a number of PAR approaches on that AC pattern. They used to come up (mostly overfly) fairly often to CFB Comox, BC (Vancouver Island) and then let them do their thing in their AR doing AAR with some of our F18's and F101's way back when. GO AIR FORCE
    Just ordered the RP-SMA type U.FL pigtail and rubber duck antenna (9dBi) from these guys online - http://www.sharperconcepts.net/
    We'll see how that goes when I bench test them. *fingers crossed* I got it right. Many thanks Barry, cheers,
    John
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  2. #22
    Jul 2006
    Working well now
    Many thanks again Barry
    I got the correct U.FL pigtail which I attached to the "Main" connector on the card and the bulkhead fitting worked just fine on my Travla case. I ended up getting two antennas. The rubber duck type that easily attached to the bulkhead fitting and this one;
    which comes with a 10' lead of cable and RP-SMA fitting as well. So I can use this one for the car - either in the rear deck or mounted on the outside when parked. An extra bonus was that the rubber duck RP-SMA antenna will attach to the magnatic base of the second antenna as well. Nice to have a few options if necessary. Again, many thanks for your assistance in this as it's always a steep learning curve for this noob.
    Now, on to the next project - finding a webcam for my car pc that has an integrated microphone. Strange that I haven't found one thread on this unless my search parameters are flawed.
    Cheers mate,
    John
    GO AIR FORCE
  3. #23
    Jul 2006
    Just A Footnote
    After many successful months in this config (not installed in car asa of yet) I decided to take my car PC with me on deployment to Kandahar, Afghanistan.
    From my hootch (tent) I can pick a lot of open sources. What's unique is that in my general tent vicinity other laptop users are unable to cature any signal from the Canadian source, whereas I have no problems. This is by using the rubber duck antenna only. So any posts you see of mine til next January will be from my "hootch" (tent) via my CarPC.
  4. #24
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by jschrauwen View Post
    Sweet! Glad it's working for you. Hopefully it's a bit cooler for you there. I was a tad further south. Pic was taken at Thumrait airbase in Oman, at 9:45am...
    Failure is not an option....
    It's installed by default on every version of Windows.
  1. Radioshark to Car Antenna
    By theminor in forum Car Audio
    Last Post: 11-16-2010, 04:49 PM
  2. Extending Antenna cable
    By paris in forum Newbie
    Last Post: 06-13-2006, 01:52 PM
  3. Replies: 9
    Last Post: 04-22-2006, 09:22 AM
  4. Antenna Question
    By thrmaln in forum Wireless Communications
    Last Post: 03-22-2006, 03:11 PM
  5. Power Antenna Control
    By fredp in forum General Hardware Discussion
    Last Post: 07-05-2005, 08:42 AM
