Results 1 to 9 of 9
Thread: DLink EV-DO Router DIR-450
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Surprised I haven't seen anyone bring this up, but then I think the thing was only released recently.
    Due to my Comcast connection crapping out earlier today, and my unwillingness to sit around while I wait for them to figure out what's going on (I work from home), I started looking around for a router that would work with my VZW Novatel V620 card.
    Lo and behold, a search for EVDO on BestBuy.com yielded this.
    http://www.bestbuy.com/site/olspage....=1158104010642
    Look! An EVDO Router that works with a bunch of cards, from both sprint and Verizon! How curious! Even better that it is NOT on D-Link's site.
    The price online is not the price in store, btw. It's a full 199 if you go to pick it up, but still a good deal!
    I've been toying with it a little bit. First of all, it's on the first revision of firmware (1.00, hardware A1), which was released Sept 6, 2006. Fairly scary, but it seems pretty solid. It's supposed to guide you through a 'setup wizard' when you connect and browse to the interface, but that part is a little weak. Just hit the 'manual configuration'. Unfortunately it refers you to the 'ISP' for your card for the connection settings, but the manual VZW settings worked fine for me (number@v[email protected], etc..)
    It'll tell you your external IP, has WiFi-G built in, four ethernet ports on the back, and a USB port I haven't figured out yet. For a router that you just want to get online with, and is fairly portable, this is a pretty good deal. The box is probably a little bigger than the Linksys.
    Let me know if you've got any questions, and i'll dig into it a little!
    Supported Cards
    Sprint
    * Kyocera KPC 650
    * Novatel V620
    * Sprint PCS Connection Card PC-5740
    * Sierra AC 580
    * Sierra AC 5220
    Verizon
    * Novatel V620
    * Verizon PCS Connection Card PC-5740
    * Kyocera KPC650
    * Sierra AC 580
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by Jahntassa View Post
    I've been toying with it a little bit. First of all, it's on the first revision of firmware (1.00, hardware A1), which was released Sept 6, 2006. Fairly scary, but it seems pretty solid. It's supposed to guide you through a 'setup wizard' when you connect and browse to the interface, but that part is a little weak. Just hit the 'manual configuration'. Unfortunately it refers you to the 'ISP' for your card for the connection settings, but the manual VZW settings worked fine for me ([email protected], etc..)
    Supported Cards
    Sprint
    * Kyocera KPC 650
    * Novatel V620
    * Sierra AC 580
    * Sierra AC 5220
    Verizon
    * Novatel V620
    * Kyocera KPC650
    * Sierra AC 580
    Not bad let see how it works cheaper the Linksys
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    difference between this and the kyocera kr1
    carputer - done.
    May 2005
    Conyers, GA
    Quote Originally Posted by shrinkydinx View Post
    Far as I can tell, this is cheaper?
    I don't have a KR1 to test it against..as said, let me know if there are any specs you want me to try to find out and we can do a compare.
    May 2005
    im sure the most important aspects are just how easy it is to use...
    carputer - done.
    Jan 2007
    sprint setup
    Does anyone know what to enter for a sprint card when it asks for usernam password server and dial number? Thanks.
    May 2005
    Conyers, GA
    As far as I can tell, the dial number is the same as verizon, #777. As for the user and password, I can't seem to find any info. You may want to try asking the people at EVDOForums. http://www.evdoforums.com/index.php
    Constant Bitrate leemik's Avatar
    Aug 2004
    MA
    I have this router and I posted pics in another thread here.. I have seen threads about this router as well so it's not exactly unnoticed..
    As for password and dial #.. it's been over a month but once i got the card activated on my laptop, i don't recall putting anything in for password dial number or anything like that on the router.. all i remember doing was selecting the card type.. I think it was plug and play.. if that's not the case I'll login to my router and look but i'm too lazy and it's too cold out right now..
    --mike
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    I've had a KR1 in the past, and this router supports VPN pass-through for Nortel Contivity and Cisco, as the KR1 did not. For the money, this is a great router.
    This adapter from RadioShack works perfect for using this router in your car: http://www.radioshack.com/product/in...entPage=search
    Jarred
  1. Wireless router to wireless router wirelessly
    By Jackso in forum Wireless Communications
    Last Post: 02-22-2010, 11:30 AM
  2. FS: Craftsman Router, Router Table, Router Bits
    By tbird2340 in forum Classified Archive
    Last Post: 10-19-2004, 06:50 AM
  3. what did I do wrong with my dlink ?
    By SAScooby in forum General Hardware Discussion
    Last Post: 04-18-2004, 03:15 AM
