Results 1 to 6 of 6
Thread: USB Adapter + External Antenna = $70 bucks worth of Wifi Improvement??
    Feb 2007
    Long Island New York
    I'm planning on getting this USB adapter for around $60
    (its a stand alone usb wifi receiver but has the option for antenna)
    http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:AAQ:US:1
    and adding this 9db external antenna that plugs into the adapter for $13
    http://cgi.ebay.com/9db-WiFi-Wi-Fi-B...QQcmdZViewItem
    Now....question...
    Would this set up improve my wifi reception SIGNIFICANTLY??
    or should I just get a regular wifi usb receiver and long usb cord for around $10.
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by pjloppez View Post
    Now....question...
    depends on what benefit wifi is going to offer, assuming that aerial is going to be used outside of your car, that would make a difference to the signal you get from your sourse (ie router).
    I have to be virtually parked at my front door to connect to my wireless router! im considering buying one as well
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Feb 2007
    bump....any more opinions??
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Now....question...
    It is impossible to know what you mean by significantly, and since antenna performance is measured in Db, the improvement will be logarithmic.
    Reception is based on MANY FACTORS, and not just antenna performance. There is just TOO much information to crunch.
    That being said, and all else being exactly equal, you will have better reception. No way to know if it will be significant.
    Michael
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    I used to have one of those radios. They're crap. That antenna isn't really designed to be used outside. If you use it that way be sure to use something like heat shrink on the joint and connector to keep out water.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    This is exactly what I've been looking for! A USB stick with connector for external antenna! (Not that specific antenna)
    When the time comes there are a lot of antennas to choose from, and I will take one that fits into my charkfin. (See below)
    But:
    This you use that specific stick too, Barry? Any good?
    Does it work well with WinXP and WZC in SP2?
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
  3. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  4. What kind of USB Wifi adapter do you use?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 01-23-2004, 11:30 AM
  5. USB 802.11b adapter with external antenna anyone?
    By cyjad in forum General Hardware Discussion
    Last Post: 12-03-2003, 10:07 AM
