Results 1 to 6 of 6
Thread: Mini-PCI Ethernet + Bluetooth Combo card
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I recently purchased a VIA Nano-ITX with a mini-pci slot on it. Iv been searching for a long time to find a bluetooth and Ethernet combo card but I could only find one that only worked on MSI notebooks. I tripped over this today while searching: http://www.pugetsystems.com/store/it...7&com=d41d8cd9
    The website is less than informative and I was wondering if anyone else knew about this or might be able to give me some info on it.
    P.S. I have searched Gigabyte's website and Google
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
    Dec 2006
    MA, USA
    More disapointment... after more research for info on that card Iv found out that its probably an MSI card making it useless. I think im just about to give up on it.
    Anyone know where I can get just a bluetooth Mini-PCI card?
    Low Bitrate Gamer64's Avatar
    Feb 2006
    Holland
    I also looked at the MSI card, but after extensive searching i found somewhere that the Mini PCI slot is wired differently then a normal MiniPCI slot. 2 wires from the MSI slot go directly to an internal USB header. So the Bluetooth part of that card is still connected to USB. I wanted to have as less parts on the USB bus as possible.
    I had a lot of USB troubles. I also bought a Firewire DVD writer Slimline that i still love the most. Even doesn`t need external power. Now i have an old MSI Plugin device for BT, a USB GPS, TouchScreen plugged in the USB. And an extra USB cable for my Joypad to the glovebox.
    All works fine now.
    If you`re not first, you`re last !
    Dec 2006
    MA, USA
    Dose anyone have a place I might be able to find a just a bluetooth Mini PCI card? A combo card would be better but they don't seem to exist so I'm left with nothing.
    The reason I'm doing this is because I have limited space and I would prefer it if I did not have to add any wires to my Nano-ITX. Any help would be grate, Thanks.
    Feb 2006
    Holland
    The only card i came across was that MSI one. I use a MSI Expansion card from some old motherboard. It came without a case (it`s some sort of plugin card for the mobo). But i soldered a USB cable to it and placed it in an external box. I also bought a 2 dollar Ebay BT Stick but that was crap. Spend a little more for a decent one.
    I use the Microsoft BT Stack BTW cause i only use it for Dail Up Networking (i have a normal parrot carkit in my car).
    Dec 2006
    MA, USA
    So i gave up on finding something like this, I guess it just doesn't exist in a generic sense... anyways if you interested Iv gone a slightly different way in this thread: AOpen in a Nano?
  1. Flexi PCI riser card bandwidth question
    By sama in forum General Hardware Discussion
    Last Post: 06-13-2008, 11:31 PM
  2. upper limit for pci video card powered by an m2-atx?
    By megagoo in forum Power Supplies
    Last Post: 05-24-2006, 07:08 AM
  3. pcmcia pci or pci card?
    By fuctup in forum Wireless Communications
    Last Post: 11-14-2004, 02:49 PM
  4. I have an Epia800 with room for one PCI card, what should i get?
    By Dominik in forum General Hardware Discussion
    Last Post: 10-11-2004, 11:13 PM
  5. PCI Video card not working
    By TX5 in forum General Hardware Discussion
    Last Post: 10-10-2004, 10:56 PM
