Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: The 2007 Scion tC + Infill G4 Project
  1. #41
    Sep 2007
    do you just connect the 12V (yellow) from the molex connector on the PSU to the yellow cable from the G4 harness? same thing for the 0V (black) to the black of the G4 harness?
    is there anything to plug?
  2. #42
    Jun 2006
    Boston, MA
    first off, nice install! i have an 07 tc as well and have been toying with the idea of a carputer.
    you said you bought the backup camera. how/where did you mount it? we don't have a trunk keyhole that would be convenient. i can't really think of a good spot for it, besides mounting an extended panel below the bumper for it.
    any thoughts? tia!
  3. #43
    Constant Bitrate DAE51D's Avatar
    Nov 2006
    Seattle, WA
    HowTo power the G4 on the bench with ATX or DC brick
    I'd like to share an excellent email I just recieved from Goce explaining in detail what needs to be done. I hope he doesn't mind I re-posted this, as I think it will help many people.
    You donít need to jump any pins.
    On the G4 you have 3 wires that are relevant to powering up/down the unit:
    • Black: Ground or negative
    • Yellow: +12V or Battery positive
    • Red: Accessory or ACC or IGN
    A General thumbs up when working with car electronics:
    -DO NOT connect positive (black) to negative (red or yellow) current. Thatís how lightning is made.
    Using ATX PSU:
    On your ATX power supply that you have you will have some 4-pin molex connectors. Cut one of them off and:
    1. Youíll have 4 wires: 2x Black, 1x Red, and 1x Yellow. Use some electrical tape to isolate the ends of the red wire and one of the black wires.
    2. You will wire together (twisting the wires and using some electrical tape should do) a black wire from the ATX to the black wire from the G4
    3. You will wire together the yellow wire from the ATX PSU to the RED AND Yellow wires from the G4.
    The one thing I will have to caution you about your ATX power supply is it might not turn on if you donít have it connected to a motherboard (so the G4 will not power on). I am not sure how much you know about computers, so Iíll explain it anyway. Pretty much if you have a 20-pin (or 24-pin) connector coming out of that ATX power supply that thing will not turn on unless that 20-pin (or 24-pin) connector is hooked up to a motherboard. There is a way around this where you cut the green and a black wire from that 20-pin connector and twist them together. This will trick the PSU into thinking that it is connected to a motherboard and it should power on your G4.
    Using Desktop Battery/AC-DC brick:
    An alternative to the ATX PSU option is to buy a 5A (minimum) rating AC-DC brick from Radio Shack. You can see on the back of the brick there is a DC rating and make sure it is at least 5 Amps (5A). Youíll splice the barrel connector on the DC (output) side. There will be two wires (probably a white shielded wire wrapped with a multi-stranded wire). Theoretically the white wire is the positive and the multi-stranded wire is the ground (also negative). TEST the wires with an Amp meter (or multi-meter) to make sure. You donít want to fry your $2k car computer.
    Connect the ground from the brick to the black from the G4 (twist them and isolate with electrical tape). Connect the positive from the brick to the yellow and red on the G4 and isolate the wires.
    So as you noticed thereís a common theme in powering up the G4 on a bench.
    1. You need to feed positive (+12V) power to the Red and Yellow wires on the G4
    2. You need to connect the ground (negative) to the Black on the G4.
    Another thing that might be useful is the RED wire on the G4 is the Accessory wire. This is how the G4 knows when your car is on or off. If you remove this wire while it is connected to a 12V source the G4 will think you have turned your car off and it will go into stand-by.
    If you have any doubts about this wait and talk to one of us. The ATX method seems a little harder but the wires are color coded (you know which is positive and negative) so you canít fry the unit. The AC-DC brick way you can mess up very easily if you havenít worked with a multi-meter before.
    Best,
    Goce
    http://daevid.com/gfx/tC
    Infill G4. StreetDeck.
    Installed 09/17/07
  4. #44
    Aug 2004
    California
    Quote Originally Posted by Narcturus View Post
    any thoughts? tia!
    I did buy the backup camera. However, for this very reason, I haven't installed it yet. I can't figure out where to mount it either.
  1. Infill G4 - Now Shipping
    By StreetDeckAce in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-05-2011, 11:53 PM
  2. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  3. 2007 Scion tC - CarPC DONE!
    By mike6789 in forum Show off your project
    Last Post: 08-31-2007, 01:01 PM
  4. 2005 Scion tC
    By lebshiff21 in forum Show off your project
    Last Post: 05-25-2007, 01:49 PM
