Results 1 to 10 of 10
Thread: 2006 MKV VW Rabbit 2.5 Work Log
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    I ran all the wiring and installed my amp today. Just gotta install the pc parts and hook it all up. I also started fabing up the bezel for my touchscreen.
    Break time
    first time using bondo, boy did it suck!
    well itll be done in a week or so and i can post more pics of my work.THANKS
    '08 VW Rabbit S 2.5
    Carputer Progress:
    Design:[][][][][][][][][][][][][][][][][][] 100%
    Fabrication:[][][][][][][][][][][][][][][][][][]100%
    Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
    In trouble...
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    Looks like you've reached that point. Good luck and keep us posted.
    Jan 2007
    Quote Originally Posted by Lazyflip View Post
    when i first started this, no one ever told me how damn hard it is! but its ok, now i know a lot more about computers and wiring then i did before. Good experience
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    Jan 2007
    This is how it will look when everything is done. Only the amp is visible.
    Closeup of the no name amp
    floor cover removed
    where i will mount computer
    computer mount i fabbed up
    how it fits, no clearance issues.
    where i plan on cutting more of the foam out and installing a CPU chassis fan
    anyone have any suggestions on keeping the computer cool besides not putting it there Keep in mind i have heavy tinting and my car has a lid thing in the trunk that does not allow direct sunlight from hitting the trunk floor but still allows air to move from the cabin to the trunk.
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    Jan 2007
    also im using a heat sink with fan and a chassis fan that i plan on mounting so that heat comes out the side. Im also thinking of putting the fan on the trunk floor and cutting out a hole for it. Something like this:
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    cutting a hole for a fan would probably be the best idea... how thick is that carpet, does it let air through at all?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Jan 2007
    Quote Originally Posted by Dennis5587 View Post
    nope, theres a sheet of wood under the carpet. Very little air would get through. I think ill end up doing that, a hole, right over the system and putting some type of screen over it to prevent damage to the fan.
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    Nov 2004
    NY
    ok, is the carpet attached to the wood, or is it just sitting on it, if so, how well does the carpet breath, you could always just put a whole throught the wood, mount a fan onto that, and then have it blow through the carpet
    Also, does any air get into there other then that one hole? if not you may need to make a second. See if you have one fan blowing out, and no other holes, you just pull the air out, giving it a negative pressure, but you never get any fresh air into there, so it dosnt work as well as it could. Same thing for if you have one blowing in, you keep putting fresh air in, but no way to get any hot air out.
    You're probably best off having some sort of ventilation holes, and one fan sucking out, this will probably be your best bet, the fan pushing out will suck in fresh air from the ventilation holes
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Jan 2007
    its glued onto the wood. Yeah ill probably do the whole in the wood with a fan and cut away the foam on the left side towards the rear to get a flow going. Thanks for the help!
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    Jan 2007
    bezel is done
    i know its not perfect but im strapped for time and cant spend more hours sanding this thing. Ill give it another go in the summer when i dont have classes...
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
  1. 2006 VW Passat Variant CarPCed (56k beware!)
    By andro in forum Show off your project
    Last Post: 10-09-2007, 10:53 AM
  2. Starting a Work Log??
    By briderx in forum Newbie
    Last Post: 04-07-2007, 03:01 AM
  3. VW mk5 OEM Nav Unit Skin (work in progress)
    By crsseyednsmilin in forum FP Skins
    Last Post: 03-22-2007, 04:46 PM
  4. 2006 VW Jetta 2.0t
    By dima237 in forum Show off your project
    Last Post: 11-29-2006, 02:47 PM
  5. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 02:53 PM
