Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 93
Thread: 1997 Ford Taurus LX Install, follow along kiddies...
  1. #21
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Power supply/SSC questions...
    For my purposes (look at the specs above) would these work?
    SSC - http://store.mp3car.com/Micro_Shutdo..._p/pwr-007.htm
    Power supply, it's been recommended to go with the OPUS units:
    180w - http://www.opussolutions.com/index.php?p=product&id=54
    320w - http://www.opussolutions.com/index.php?p=product&id=49
    but are there any other suggestions before going right on into these?
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #22
    May 2007
    Lakehood, CO
    what about this from opus:
    http://www.opussolutions.com/index.php?p=product&id=33
    This would solve a few problems at once.
    Where to get it? (No Buy-Here button on the web page)
    This seems to integrate the SSC, PSU, and case in one package, so all i do is put my mobo, HD, and cd-drive on in it, and I'd be pretty good to go. (mounted on top of my Sub box...maybe)
    What do you guys think?
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  3. #23
    Mar 2006
    Colorado, but Canadian!
    All the opus PSU's you linked to, have SDC built in. And the mp3car store has them, but Opus should allow you to buy it.
    I think they are just updating the website, because if you go to the 320W: http://www.opussolutions.com/index.php?p=product&id=49
    there is still the buy now button where it should be on all of them. So they are definately messing around with the site right now.
    1.9in x 2.9in -- 47mm x 73mm
  4. #24
    May 2007
    Lakehood, CO
    it was the opusdirect website i couldn't find it on, there were only ITX cases, (i have an ATX mobo) and that is the one I'd be interested in, it would save a lot of fab time, (i know there are many atx cases out there, but this has the vibe damping for car pc applications...)
    But, i'll be more focused on my remote start the next few days anyways...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  5. #25
    May 2007
    Lakehood, CO
    i had a thought today while postulating what to do for a case.
    I want something that could fairly easily be removed (if I wanted to) and fairly small for a full size ATX mobo, and I came to think I could fit the components in a car audio amp case.
    Why not? it is designed for high heat situations, and already has terminals for power and ground wires and it's fused too. I could stuff all the components into a medium to large size amp case after it's all gutted. I'd leave out the CD drive, and use only external drives, and may look at a laptop HDD (better for in car use and smaller.) I'd of course find some way to cool and vent everything, probably mount everything to the top of the amp case, and install fans on the bottom cover. (the puter would be oriented upside down) and place the PSU and HDD on the bottom cover. Also I'd run the VGA cable through a female connector i'd install on the case. This way it could be mounted the best way to fit in the amp. Also, it would look like a "crappy" amp and would most likely not be a temptation to be stolen. This whole thing would be mounted on the sub box, where my current amp is located, and my current amp relocated to the top of the box. (I'll show pics soon of this.)
    Anybody tried this and failed? comments?
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  6. #26
    Mar 2006
    Quote Originally Posted by monkeyracer View Post
    Check out the Ampie/VoomPC or Ampie2/VoomPC2 case. It is just this. But for ITX. Houses optical drive, mobo, 2 harddrives, and a M2. So for a full atx board, you will need to find a big amp, but it will work. May even be able to make the amp casing a huge cpu heatsink.
  7. #27
    May 2007
    Lakehood, CO
    that's another reason I was thinking about using these. there are some rockford amps that are broken on ebay for a few bucks. That's why i'd mount the motherboard to the top of the amp, it would be right on the heatsink. Meaning a small fan and exhaust port should be enough to keep it cool.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  8. #28
    May 2007
    Lakehood, CO
    Today, I have the opportunity to install my remote start system, I'll post a write up on how I did it later today. Also, I will start constructing my fiberglass sub box. Here's a diagram of the MDF, then I will stretch the fleece over it, and start work on glassing it. (Glassing may not happen until saturday though.)
    Diagram:
    In the end this box will have an estimated internal volume of about 1.3 Cu Ft per side, which is kind of big for a 12, but with the curves, the internal volume will be a little less, hopefully around 1.1 to 1.2
    I'll post a write up on this as well, it will be located in the fabrication forum, look for it there soon.
    Now it's off to the depot for a few supplies!
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #29
    May 2007
    Lakehood, CO
    Okay, all of a sudden, not feeling so great , going to take the afternoon off, so no box frame today.
    I did finish the remote start though, and i've decided not to post a write up, i didn't take any pictures anyways. Pics for sure on saturday when I build the box.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #30
    May 2007
    Lakehood, CO
    ok, something i noticed about my car after installing remote start:
    I have two accessory wires. I wired the remote start into the main one, leaving out the second one (need relays, etc.)
    What this means is that I can wire the carputer to the main accesory wire, and the deck and screen to the secondary one. When I start the car, the computer starts to turn on, but will not display anything or play any music (I'll have RR default to pause on resume) and when I get in the car and put my key in, the CD Deck and the screen will turn on, and I just press play. As soon as I get out and turn off the car, everything will start to turn off.
    This all started because I was being lazy and didn't want to wire two relays to join the two accessory wires. It turned out to be a good thing.
    I'll need more range though, the package states up to 500+ feet. I get usually about 100. Any suggestions?
    Also, I don't like the remote too much, can I program a different style one to this? Meaning any DEI remote start remote remote?
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 11:41 AM
  3. Screen placement in '05 Ford Taurus
    By Rafster in forum Fabrication
    Last Post: 04-28-2005, 06:36 AM
  4. Ford Escort 1stGen(89) install in progress
    By yonu in forum Show off your project
    Last Post: 03-27-2005, 02:58 PM
  5. 2nd Gen Ford Probe - Anyone have install experience?
    By PSUSuperSenior in forum General Hardware Discussion
    Last Post: 02-15-2004, 11:17 AM
