Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 93
Thread: 1997 Ford Taurus LX Install, follow along kiddies...
  1. #61
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by monkeyracer View Post
    ok, back to the drawing board. that kit did not work. it's designed to go in front of a double din screen, rather than have a ddin hu slide into it.
    the search continues...
    Im pretty sure that is how they all are...
    You have to secure the screen/HU to the mounting plates in the dash, and then the cover does just that. Covers the whole. The cover itself provides no structural support. You can still keep the screen, just where you secure it will be to the original metal tabs in the dash.
    1.9in x 2.9in -- 47mm x 73mm
  2. #62
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    my dash fab has not been done before, by anyone with this car. Metra's kit calls for a single din radio since the climate controls are on the panel. For the double (triple with the deck) din opening, I am relocating the HVAC.
    The post from a few posts back, with the rough mock up of the layout shows that the middle piece between the stock radio area and the ashtray area will be cut. Then I am going to cut ABS sheet to that same area, (thermoformed to match contours) and secure the screen to the front piece of ABS, and the ABS will secure with custom fabbed clips. I was going to try the pre-fabbed metra kits to give it a really nice straight edge, but I'll probably end up using the original screen bezel anyways.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #63
    Mar 2006
    ah well.... You could always order a spare screen bezel from Armen, and then you can do all you fab on the spare so that you dont mess up and get left with a mess.
  4. #64
    May 2007
    Lakehood, CO
    Got the screen in the other day, and it's amazing! At first, next to my laptop 15.4" screen it looked tiny, but then I temporary mounted it in the car, and it's definitely big enough. I got my laptop to display 800 x 480 through the on board card. I want to have this fabbed and in the car in less than one month (may have to use the inverter to get me by until I can get the PSU. I will be putting the inverter in for the PS2 anyways...)
    The screen is really bright at night, I have to set the auto gamma pretty dim for it to be comfortable. In the daylight, it's as I expected, a little reflection washes some of it out, but I didn't have any problems with reading the screen. I feel like I'm calibrating it way too much though. It should be one time, and you're done. I think it's because I'm connected and disconnecting it to/from my laptop, and once the actual car pc is in it will keep the calibration settings in tact. (That freaking beep that it makes to confirm the screen calibration is so annoying, my girlfriend vowed to do terrible things to it if she ever had to hear it again...)
    Also, my gps antenna seems to be a little picky. When I plug it in, usually I have to go to GPS info, then start the gps to test the signal, then close that, open iguidance outside of roadrunner, then if it acquires the signal, I open roadrunner. Sometimes if I change skins, or do certain things in road runner, it loses the GPS, and I have to close everything out, disconnect the antenna and reconnect the antenna, and start the process again. (I think though since I am disconnecting, reconnecting, etc it's causing some issues, so with the actual computer this may solve some issues.)
    Anyone have any suggestions with this?
    @2k1 - I didn't think armen had any bezels for dynamix screens, I thought it was more lillis and xenarcs, But I'll ask him anyway. I may be able to get any 8" wide screen bezel though and fab that. The dynamix screen doesn't mount the front to the back bezels the same way as the lillis and xenarcs, so i'll have to come up with a way to do it (really not that hard though)
    I think my plan for now is to just make a mold out of thin wood, sand and filler to perfection and gravity thermoform the abs over the mold in the oven. Then cut out the appropriate holes. I'll be ordering some abs and going to buy some thin wood later this week. Fab will be a little delayed since I'm going to the projekt revolution tour concert (pit tix) but of course progress will be posted here.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  5. #65
    May 2007
    Lakehood, CO
    i figured out the gps issue I think. Roadrunner and iguidance were trying to access the same port, and since rr opened first it caused conflict. I just have to set it up correctly and I should be good to go...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  6. #66
    May 2007
    Lakehood, CO
    that's all that was, what's wierd though is that regardless of what I change the option to in RRconfigGPS it will only show km/h for the label code "gpsspd" I'll ask in that forum though.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  7. #67
    May 2007
    Lakehood, CO
    Ok, bouncing a few more ideas here, I think it would be way easier to make the dash square than to get everything to line up right with the curves. I'm headed to a junkyard today to see about getting a second dash piece. What I would do is strip the vinyl from the dash piece, cut the right parts, fill the space with abs or fiberglass to make it have straight edges, then wrap it in matching vinyl. This would leave a space approx 8" x 11.5" which I would then be able to mount all the components to a piece of ABS cut to the right size. I now need to find a place that will cut my hvac control masks, so that I can fabricate the mount for that.
    Also, the cupholder idea failed, so when I go to the junkyard, I'm going to see if they have the alternate cup holders for this car, or if they have a different car that has something that would work.
    I'll report back later with what I find...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  8. #68
    May 2007
    Lakehood, CO
    ok, started bezel fab, here's the first few shots:
    I started with a 12" x 12" sheet of abs plastic and cut it to 8" x 12" and then measured out the bezel and cut out the right size. Then I used oatey brand abs cement (designed to glue together abs pipes) to glue the bezel in place, and then filled the front face of this for a stronger bond. I will sand this down and then put a little more in the low spots. I am using this cement because it's basically a manufactured version of our home-brew abs sludge, same stuff (MEK and ABS) but is mixed to an optimum mixture (to thin it out, add mek, thicken add abs regrind...) and comes in a sealable container. This method allows the LCD bezel to be chemically bonded as one piece to the abs sheet. (I will use this for the DVD drive and a few other small pieces.)
    More shots and directions as the process progresses.
    At the junkyard, I found a dash piece.
    This was from a '98 but it wasn't plastic wrapped in vinyl, it was textured plastic made to look like vinyl, but has a hard touch to it.
    It was a little broken, but in a spot that would be cut out anyways. I cut the space out and will fill in the empty spots with abs. The hard part with this is to keep it straight while I fab everything and to figure out how to mount it. Also, while I was there, I saw a trashed mustang that had a very similar hvac control layout as the taurus, and the connections looked pretty darn close. I think I'll head back down there, take it out, and go to one of the taurii they have and test fit it... Hope it works, because it would save me a whole lot of time and effort.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #69
    May 2007
    Lakehood, CO
    ok, more bezel work:
    I sanded the first layer of abs down with a few different types of sandpaper. To make sure that it stayed straight, I wrapped the sandpaper around a pink eraser, or used a sanding sponge.
    Next, I filled the low spots with more abs cement.
    And, sanded again until it was nice and smooth.
    Next step is to finish a few more tiny little low spots, sand those down, and then cut out the holes for the DVD drive, the pioneer deck, and to figure out what to do with the HVAC controls. After all that is done and the whole thing is smooth (no haircell texture) I'll paint it with some Krylon Fusion Texture paint. This paint is designed for plastics, so no primer is necessary, and it leaves a light texture, almost resembling sandpaper. Rather than using the thick texture paint that most here use, this is a (imo) better option.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #70
    May 2007
    Lakehood, CO
    texture paint test on a lego:
    it's a more subtle texture, so I think it will work very nicely!
    It will hide imperfections, but it's still good to have a smooth base to apply it to. Also after a week of curing time, it is supposed to be scratch and chipping resistant, so that's cool.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 11:41 AM
  3. Screen placement in '05 Ford Taurus
    By Rafster in forum Fabrication
    Last Post: 04-28-2005, 06:36 AM
  4. Ford Escort 1stGen(89) install in progress
    By yonu in forum Show off your project
    Last Post: 03-27-2005, 02:58 PM
  5. 2nd Gen Ford Probe - Anyone have install experience?
    By PSUSuperSenior in forum General Hardware Discussion
    Last Post: 02-15-2004, 11:17 AM
